Shower Light Switch Too Close? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 11:54 AM   #1
shower light switch too close?
does anyone knows if this is code compliant im talking about a closed shower with a glass door that has a light switch outside the shower right next to the door the switch controls the light inside the shower,,,i know about the 3' rule but thats for open showers as i stand know i believe this set up should be okay but then again i havent cheked the 2011 nec so what do you guys think.
RAUL HIDALGO is offline   Reply With Quote
Old 01-06-2013, 11:56 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
It's fine.
What "3' rule" do you know about?
Speedy Petey is online now   Reply With Quote
Old 01-06-2013, 12:05 PM   #3
Originally Posted by Speedy Petey View Post
It's fine.
its on the nec it says that fixtures and outlets should be 3 feet away from the shower and 8 feet high from shower stub
Old 01-06-2013, 12:14 PM   #4
Not true. Receptacles and switches can be right next to a shower, but not within. Fixtures can be anywhere from inside the shower, to limited to 3' away. Depends on the fixture and wiring.
Old 01-06-2013, 01:39 PM   #5
Rewards Points: 948
I don't have any idea what the code requirement is, but in the same situation I used an outdoors switch.
Toller is offline   Reply With Quote
Old 01-06-2013, 02:26 PM   #6
A) You mean with an outdoor cover?? Ewwwww.
B) If you have no idea what the code is WHY are you doing this work?
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
brric (01-06-2013), Jim Port (01-06-2013)
Old 01-06-2013, 02:56 PM   #7
" Euro " electrician
frenchelectrican's Avatar
The USA side the switch for shower or bathtub as long it out of the footprint pattern you can use the conventail switch aka standard wall switch.
Make sure you get the luminaire that is rated for shower useage if recessed can get one rated for wet location aka shower trim but watch the lamp wattage restriction they are typically either 40 or 60 watts depending on the trim lens.
Just a side note : Our European reguations do required the switch to be a meter (3 feet ) away from the shower or bathtub foot print. ( simauir to Canada codes )
Merci,
Marc
Old 01-06-2013, 04:45 PM   #8
Engineer
Rewards Points: 161
Merci,
Marc
I have a relative that's an electrician in the UK. When he visits he has always found it odd that the US has never adopted something similar. I'm guessing at some point this will make its way to the NEC.
diystephen is offline   Reply With Quote
Old 01-06-2013, 08:32 PM   #9
Missouri Bound's Avatar
Lets hope not. There are tons of crappy laws and regulations that other countries have that have no place in the US.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
jaydevries (01-06-2013)
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 07:07 PM
Ceiling fan - Light on dimmer switch, Fan on normal switch renderflux Electrical 3 09-10-2012 02:36 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 04:23 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
