Old 10-23-2010, 10:51 PM   #1
Shower light?
Well... I finally finished everything and it was all fine. There were a few things that I needed to clean up (like extending out some boxes and putting on face plates) but I'm pretty much ready for my final inspection on Thursday.
I've run into one small snag... In my bathroom, I was trying to figure out why my shower light wasn't going on when finally it hit me... I ran a wire from the switch to the shower light but didn't think of running a supply to either the switch or shower. DUH!!!
Anyway... My bathroom fan (represented as a light in my diagram) is being fed from an outlet into the switch into the fan/light. I would like to take the feed from that fan and feed the show switch so I don't have to rip any walls apart running any wires. Is this acceptable code? I think it will be okay, but here is what I want to do:
jim.thornton is offline   Reply With Quote
Old 10-23-2010, 10:52 PM   #2
Shower light?
FYI... Black/red wire is really just black. I made the diagram this way so that it can easily be seen that it is a separate wire.
Oh... and the white isn't getting connected to that switch at all.
Old 10-23-2010, 11:07 PM   #3
Shower light?
does this ckt only appear in this bath?the outlet and light?if outlet/light ckt appears in another room,lights can't be wired off of the outlet ckt.per code 210.23(a) 210.11(c)(3).and don't forget gfci.
oleguy74 is offline   Reply With Quote
Old 10-23-2010, 11:20 PM   #4
Shower light?
Yes... The full circuit is protected by GFCI and it is dedicated for the bathroom ONLY. It actually looks like:
Supply -> GFCI -> Wall light -> Ceiling light -> Outlet -> Switch -> Fan
The wall light and ceiling light each have a line for their OWN switch.
Basically all I want to do is tap into the power that is feeding the switch for the fan and use it to power the switch for the shower. Then I won't have to run any new wires.
BTW... I'm in Ontario, so it is Ontario code that I'm concerned with.
Old 10-24-2010, 12:00 AM   #5
Shower light?
I guess we need to ask where you are from.it is hard to give advice to someone that don't use the nec,usa.I will be sure to ask from now on...have a friend that lives in Welland ontario,canada.He teaches at I belive NIAGRA COLLAGE.have a good one...mike..
Old 10-24-2010, 12:02 AM   #6
Shower light?
Thanks anyway.
Any input from the Canadians?
Old 10-25-2010, 01:54 AM   #7
Shower light?
If there are any canadians that can give some input here I would really appreciate it.
Old 10-25-2010, 06:30 AM   #8
Master Electrician
Shower light?
Great way to burn up the wires with inductive heating. Very creative too.
Mark
busman is offline   Reply With Quote
Old 10-25-2010, 08:47 AM   #9
Shower light?
I'm sorry but I don't know what you mean by that.
Would what I'm suggesting not work?
Old 10-25-2010, 09:20 AM   #10
Just call me Andrew
Shower light?
Are both switches in the same box?
You can split the feed to your first switch and supply power to your second switch also. You have to make sure you follow box fill rules....I am not familiar with the Canadian rules on that though.
How about you explain yourself and offer a suggestion instead of being condescending and sarcastic?
Andrew
secutanudu is offline   Reply With Quote
Old 10-25-2010, 09:32 AM   #11
Shower light?
Thanks for the backup.... To clarify a bit more. The switches are located in a Quad-Box (four switches). They are right next to each other.
Old 10-25-2010, 09:34 AM   #12
Just call me Andrew
Shower light?
Do you have unswitched hot power and a neutral in that box?
Andrew
Old 10-25-2010, 09:41 AM   #13
Shower light?
If I am understanding you correctly, the power supply goes from the breaker, into the GFCI, into the wall light (a wire goes from there to the switch for the wall light) the power continues on (bypassing the switch) into the ceiling light where a wire again goes to the switch for the ceiling light and the power continues on to the outlet from there it goes to the switch for the fan (here is where I want to split it) then it goes to the fan and stops. Where I would split it there is power 100% of the time regardless of what other switches are doing.
Old 10-25-2010, 09:47 AM   #14
Just call me Andrew
Shower light?
Then you should be fine.
Andrew
Old 10-25-2010, 09:51 AM   #15
Shower light?
Thanks... I notice you are from Albany, NY. Are you familiar with Ontario code?
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 05:22 PM
shower light debd Electrical 4 02-12-2010 05:50 PM
Recessed light directly over shower adpanko Electrical 33 09-16-2009 07:56 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
