#1 |
shower light
We are expanding our bathroom and putting in a shower. But I'm thinking it will not have enough lighting in it. I have seen showers with lights in them. Is this a special light fixture since it will be in the shower stall? What problems will I run into being so close to water? Does something special have to be done with the wiring? Thanks for any help.
#2 |
Xtreme DIY'r
shower light
If recessed - only kind I would install it needs to be rated for a wet location I think (maybe just damp ?)
I have one going in my new shower & it will be sealed with a solid glass trim & gasket GFCI is a good idea, but not required unless by mfg |
#3 |
Household Handyman
shower light
Put two of these in my home a few years back. Recessed can for damp location, with tempered clear glass cover for damp location. As recommended by two licensed friends and my electrical supply house buddy. Each bath wired as normal lighting circuit(s), BUT a separate 20 amp circuit with dedicated GFCI breaker feeding the two. I love this/these lights. I'm washing parts I didn't know I had until I put in adequate lighting.
David
#4 | |
shower lightQuote:
#5 |
Electrical Contractor
shower light
No separate circuit or breaker required. Check with the manufacturer of the light to determine if you need GFCI protection, however.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Ceiling Fan with Light kit - Light not working | aadams | Electrical | 12 | 11-03-2010 07:32 PM |
| Recessed light directly over shower | adpanko | Electrical | 33 | 09-16-2009 07:56 AM |
| Please Help! 3 way switches controling 2 light fxtures. | HelloMotto | Electrical | 50 | 09-01-2009 09:20 PM |
| redoing basement shower - basic questions (relocating drain/options I have) | mslide | Plumbing | 5 | 10-28-2008 11:42 AM |
| Light Socket Won't Hold Light Bulb | colhollywood | Electrical | 3 | 08-16-2008 09:28 AM |
