Show Me Your Neatly Wired Panels? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 12:05 PM   #16
Originally Posted by xxPaulCPxx View Post
In my panel, I put a map detail what each room was, and where the subpanel in the garage was... it included the words "You Are Here". All the electricians who've seen it got a kick out of that.
At the junction box in the attic, I have the spreadsheet of what each circuit does/goes.
can you make some pics? I've been thinking of using a small blueprint picture to show circuit locations... maybe if i see yours that'll push me over the edge.
dkliman is offline   Reply With Quote
Old 08-30-2010, 12:12 PM   #17
Licensed electrician
Rewards Points: 1,472
I have used Broderbunds 3D Home Architect to make simple blueprints with the receptacles shown. I put the circuit number near each outlet.
Old 08-30-2010, 12:29 PM   #18
Originally Posted by cgoll View Post
No spagetti here!
I take no credit for this work; I don't even remember where I got the picture.
The last time I saw cabling run that neatly, it was in a Bell South central office. (Everything is cabled that neatly in a central office.)
Too bad we don't know who was responsible for that. I'd buy them lunch just for doing such nice looking work. (But not spaghetti. I suspect they'd have to route each and every noodle straight before they could eat. )
KAdams4458 is offline   Reply With Quote
Old 08-30-2010, 12:34 PM   #19
Totally screwed together
The map is a little faded in the box, and unfortunatly I don't have the Punch software loaded on this system or I would post the file.
I wish i knew how to post bigger pics!
xxPaulCPxx is offline   Reply With Quote
Old 08-30-2010, 12:44 PM   #20
the best thing is to edit it in photoshop, and use its "save for web" feature to make it as large as possible without going over the limit. if you have the file you can send me the file and i'll fix it up for you and post it. just pm me.
Old 08-30-2010, 07:58 PM   #21
Rewards Points: 150
I replaced my load center a few years back. Removed a 10 circuit BullDog Pushmatic 100A panel and replaced with a 30 circuit CH 100A Load Center. Here in my area it is code for conduit, so I ran all new pipe and wire, replaced all outlets and switches, and split the circuits. I also installed a subpanel in the garage and a T101 timer for the outside lights. I also strategically installed GFCI outlets to run on the timer for holiday decorations, so no more need for extension cords. Believe it or not, I did the entire upgrade for roughly $300 out of pocket.
E-Bay rocks!
TJ_in_IL is offline   Reply With Quote
Old 08-30-2010, 08:00 PM   #22
looks purdy!
Old 08-30-2010, 09:10 PM   #23
Rewards Points: 502
Upgraded from 200 amp service to 400 amp service dual panels.
The original panel was a push-o-matic piece of junk.
show me your neatly wired panels?-before.jpg   show me your neatly wired panels?-after2.jpg
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 08-30-2010, 09:18 PM   #24
An electrician installed my 200a panel
So no pics of a neatly wired panel
Some day I will straighten it out
I did spend some time right after it was installed re-arranging
So it doesn't look that bad any more
Old 08-30-2010, 09:24 PM   #25
" Euro " electrician
frenchelectrican's Avatar
I know someone mention super neat wiring in the photo.
Let me fill you in couple details that was in NJ { not sure excat where } and this is a very large house and I did read the details it took couple guys a quite a while and they are very "anal" how to run them in super neat and this guy is a inspector and he took a photo what it look like.
And he mention that one of few neatest installment he ever see ditto with Data/ Comm / Tv network as well.
Even in the Pro forum { only for electricians } they just love that photo as well.
I don't useally see that super neat very often but it make super easy to troubleshooting it.
Merci.
Marc
Old 08-31-2010, 01:37 PM   #26
I like how some of you are leaving service loops, so you have extra wire if you ever have to scramble breakers around, etc. I did the same thing on the last panel I replaced, and I remember the inspector thought it was a great idea, and went on for a while about how everyone should take the time to do it that way. Nice looking work, folks.
Tags
breaker , connectors , panel , romex service panel , wiring
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Questions about mounting PLYWOOD solar panels to a roof romesa Electrical 12 05-04-2009 08:06 PM
Can I use "Exposure 1" panels on a deck that will be covered with ceramic tile? CliffQ Building & Construction 6 05-17-2008 06:45 AM
Where to get bathroom panels similiar to rebath? Side panels? twilightcall Remodeling 2 03-06-2008 09:19 AM
Pillar fence post with recessed panels on two sides derby2* Carpentry 1 05-18-2007 11:52 AM
