Should My Retaining Wall With Rebar Be Bonded To Pool Grid? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 09:06 AM   #1
Should my retaining wall with rebar be bonded to pool grid?
Hey guys I have a retaining wall about 15 feet from the edge or the pool. Its all concrete pass between wall and pool. The retaining wall is made of faced cinderblock and rock. The cinderblock part is filled with concreate. This part of the retaining wall has rebar in the base for added support. The pool equipment is about two feet away. The pool equipment is properly bonded to the pools bonding grid. However should the rebar in the wall have been bonded to the grid or is the distance far enough away?
Been reading about this whole bonding thing and figured i would ask
Thanks in advance
AlwayzSomethin is offline   Reply With Quote
Old 05-24-2012, 09:38 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks in advance
No. Not required.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 05-24-2012, 01:25 PM   #3
Measure the AC voltage between the pool concrete and the retaining wall concrete. Concrete is reasonably conductive.
If it's 0.00 vac then connecting the two together won't make any difference.
If it's more than 1 volt some people with wet skin touching both may sometimes feel a tingle, or worse.
This should be interesting.
Old 05-24-2012, 01:41 PM   #4
INTERESTING IT US!!!!
How would i do that???
Old 05-24-2012, 05:25 PM   #5
Use any multimeter on the AC volts scale to measure the voltage between the pool concrete and the retaining wall concrete that is 2' away.
Old 05-24-2012, 07:24 PM   #6
Licensed electrician
Rewards Points: 1,502
The bonding is to equalize the potential between two conductive surfaces you could be touching at the same time.
Old 05-26-2012, 04:20 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's 15 ft away, how the funk would you touch the water and the wall at the same time?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (05-26-2012)
Old 05-26-2012, 04:43 PM   #8
"The pool equipment is about two feet away." ?
Old 05-26-2012, 04:46 PM   #9
E2 Electrician
Two feet away from what?
EDIT - and what does that matter?
Old 05-26-2012, 04:48 PM   #10
I should have asked the OP that question.
Still, I'd like to know what kind of potential difference there is just for my general knowledge. At 15' he'll need to use an extension cord as a test lead.
Old 05-26-2012, 04:52 PM   #11
E2 Electrician
I don't get where you are going with it, who cares if there is a voltage potential, you're not going to be able to reach 15' from the pool water to the retainment wall.
Old 05-26-2012, 05:00 PM   #12
They are huge, grounded, conductive masses. The measurement will help me decide what ground voltage differences are plausible and what are off-the-wall.
I hope.
My motives for being on this forum are different than yours.
This kind of measuring, calculating and rechecking are what got me illegally forced out of the corrupt federal agency that I once worked for.
I guess I haven't learned my lesson.
Old 05-26-2012, 05:04 PM   #13
E2 Electrician
I hope.
You're missing so much general knowledge on stray voltage though, not saying you'll never grasp it, but at first look, its going to be way over your head, let me post you a link so you can indulge yourself in.... hang a second....
Old 05-26-2012, 05:06 PM   #14
E2 Electrician
Watch the whole video, very good watch..... might be a little hard to grasp.
Old 07-05-2015, 10:43 AM   #15
Rewards Points: 88
How does one test, or measure, the "potential" of various electrical and metal components around a pool? Is a multi-meter used? If so, what is the process? Thanks.
Kandeya34 is offline   Reply With Quote
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 08:39 PM
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 10:18 AM
retaining wall around chimney stack Master Brian Building & Construction 0 08-25-2010 03:27 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
