Should I Splice To Shorten Length? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 11:13 AM   #1
Rewards Points: 137
Should I splice to shorten length?
I am building a wood shop in my basement and need to run a series of outlets. I am using 12/2 and a 20 amp circuit. I have a 50 foot run to where i want the first outlet. I would then need to go another 40 feet around portion of the basement and back to where the wire came from to connect all of the outlets. Would I be better off splicing the wire at the 50 foot mark and running 2 20 foot sections to reduce the length or just run on continuous length?
Thanks,
Troy
Troy32 is offline   Reply With Quote
Old 12-08-2012, 11:40 AM   #2
Rewards Points: 150
Thanks,
Troy
The fewer splices you make, the fewer places for a connection to come loose.
Dave632 is offline   Reply With Quote
Old 12-08-2012, 12:09 PM   #3
Rewards Points: 137
Exactly. I like to make as few connections as possible but also did not want a 90ft run on a circuit that will have high amp draw machines
Old 12-08-2012, 12:40 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Are you saying the last receptacle is nearer the breaker box than the first receptacle? I can't picture your layout. Can you post a diagram.
Coastal South Carolina
Old 12-08-2012, 01:30 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,.... Sounds like just callin' the last outlet, the 1st, insteada wirin' a loop around the shop, would work...
Come outa the box, to the gang of outlets, 'n then continue on to the last outlet...
Old 12-08-2012, 01:46 PM   #6
Rewards Points: 150
You can "T" in an outlet or junction box to shorten the total length of run.
90 ft with 12/2 wiring will have minimal voltage drop.
Old 12-08-2012, 01:51 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The only reason I would choose to make that run shorter would be to decrease the cost of the installation.
Old 12-08-2012, 04:40 PM   #8
Rewards Points: 137
Imagine a question mark and the box would be by the bottom of the question mark. The outlets will go all the way around 3 walls. I already have plenty of wire so cost does not play a factor. Either way will work but I was curious which way a professional would run it.
Thanks for the info so far
Old 12-08-2012, 05:15 PM   #9
Licensed electrician
Rewards Points: 1,234
Run the wiring however makes the most sense and uses the shortest amount of wire. There is no reason to backtrack.
NJMarine (12-09-2012)
Old 12-08-2012, 06:31 PM   #10
Rewards Points: 137
That was the question. What makes the most sense?
Old 12-08-2012, 08:09 PM   #11
Engineer
Rewards Points: 161
I think to get the correct advice on this project you'll need to post some more detail. Above you list "high amp draw machines." What exactly are you planning to run of the 20A circuit? It's entirely possible that you'll need more than 1 circuit, so that could impact the wiring layout.
diystephen is offline   Reply With Quote
Old 12-08-2012, 09:13 PM   #12
Rewards Points: 137
I will be using up to 15 amp tools but never more then one at a time. One circuit should be fine
10 Cable Junction Box Splice swstx Electrical 8 07-06-2010 10:16 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 06:38 PM
total effective length question drewhart HVAC 2 01-27-2009 09:46 PM
to splice or not to splice treedoc Electrical 4 01-19-2008 11:56 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 03:21 PM
