Should I Rewire The Whole House?? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 03:05 PM   #1
Should I rewire the whole house??
Hello all, I am renovating a two story duplex that was flooded out in New Orleans. The bottom was flooded out but the top is in great condition.
My question is should I totally replace the electrical from top to bottom or would it be ok if I replace the bottom and keep the original wiring at the top.
I want to save money of course but I don't want to jeopardize the integrity or safety of the house.
I look forward to hearing from you guys.
Mark
blaclightn1 is offline   Reply With Quote
Old 07-26-2007, 03:38 PM   #2
joed's Avatar
Rewards Points: 12,000
The wiring that has not been under water it would not be damaged. If there has been no roof and the rain has been on these cables then replace them.
If the whole house is being gutted to the studs then you must bring the whole house up to current code. That means AFCI in the bedrooms among othre things.
Old 07-26-2007, 04:29 PM   #3
The bottom has been gutted but the upstairs is still in the same pre-katrina condition. The roof is in good condition so there was no water at the top!
Thanks for the info..
Old 07-27-2007, 08:11 PM   #4
joed's Avatar
Then you should be good to go. Just remember when you are reconnecting to the upper level you must make all your connection in accessible junction boxes. You bury any connections inside the walls.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 05:05 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
