Should I Need To Replace The Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 11:25 AM   #1
Rewards Points: 30
Should I need to replace the breaker?
Microwave and gas stove starter are on the same 15AM breaker. Lately, while we're using the microwave, the breaker goes out/tripped. Happens few times a day. I have to reset the breaker.
hpdad is offline   Reply With Quote
Old 06-28-2012, 11:33 AM   #2
kevinp22's Avatar
what is the wattage rating on the microwave? (it might be listed as 1.xxx kw)
kevinp22 is offline   Reply With Quote
Old 06-28-2012, 02:55 PM   #3
Rewards Points: 30
I am at work do I asked my wife and she said read the out put is 1100W. I don't know if it's right number rating.
This is the microwave built-in over the kitchen.
Old 06-28-2012, 03:05 PM   #4
Rewards Points: 826
If you plug micro into another outlet via extension cord ( use a beefy cord at
Least 14 AWG) does it trip that branch circuit?
curiousB is offline   Reply With Quote
Old 07-01-2012, 09:13 PM   #5
Rewards Points: 30
Used 12 AWG to plug into another outlet and it was fine in the last few days.
Old 07-01-2012, 09:37 PM   #6
Missouri Bound's Avatar
When breakers trip repeatedly then tend to weaken. If the microwave works OK used on another circuit without tripping the breaker then the breaker itself may be the issue. Are you competent enough to change out a breaker? (No insult intended, but there are scores of dead folks who said "sure, I can do that") If not, get someone who is both knowledgeable and capable.
Do you want it your way or the right way?
Old 07-01-2012, 10:16 PM   #7
Master Electrician
my vote goes for the weak breaker as well. The microwave draw 9.5ish amps and a ingiter usually only runs around 3.5amps. Even if they're both on they're still well under what the circuit can hold. Either your breaker is bad or you have a high resistance short somewhere are the two things that jump to mind first.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-02-2012, 08:05 AM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Do you have access to an Amprobe and are you capable of using it safely? If so, take a measurement to see what the current draw is. Then go from there.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Checking a Breaker Klawman Electrical 11 02-18-2010 07:48 PM
Do I need to replace my circuit breaker box? greenlantern Electrical 7 08-11-2008 11:27 PM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 04:01 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
