Old 11-10-2012, 11:08 AM   #1
should I leave flex conduit in the walls?
So I have a bathroom light switch on my 1960s ranch that currently is outside the bathroom door. I want to move it into the bathroom. Since I am also adding a bathroom fan I will be rewiring the light to a 2-gang box using new romex from the panel. However, the current switch is wired via a flex conduit that comes from the attic down to the receptacle that is likely stapled to the inside of the stud. I will attempt to remove the existing switch box but although I would love to remove the flex conduit entirely from the wall, I may be unable to unless I open a large hole(s) on the wall to find all of the staples. I would prefer not to have to make the holes.
My question is, if the conduit is cut flush to the access hole in the attic and the switch box is removed from within the wall, can I close the hole where the original receptacle was and leave the flex conduit/wire in the wall?
Thanks!
fabster is offline   Reply With Quote
Old 11-10-2012, 11:36 AM   #2
A "Handy Husband"
rjniles's Avatar
As long as the wire is disconnected at both ends, you can abandon the flex in place.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
fabster (11-10-2012)
Tags
electrical, flex, rewiring
How to plug unwanted and leaking conduit? gernith General Discussion 6 08-08-2010 01:09 PM
Flex Conduit for LV or coax? tonyBagadonuts Electrical 9 03-23-2010 11:08 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
