Should I Buy These Generac Generators For 100. Each? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 06:58 PM   #1
should I buy these generac generators for 100. each?
found a crazy deal today as im a 'picker' and have been doing this since before it was a tv show. heres what i found, generac backup generators that the output is 90 volts of DC current. they run on nat gas or propane via a switch. my question is how can i use these generators to run stuff on my catering mobile taco/food truck or backup power for my house? i need AC current and according to literature on the web, the generators are 14kw and some are single phase and some are 3 ph. i know that i can just drop a leg on 3 phase to get single ph. but how to get ac i dont know.
im guessing the engines would be kewl on a go cart and use a propane tank for a gas tank, right? any help on elec conversion would be appreciated.
vintagecarlover is offline   Reply With Quote
Old 05-02-2012, 07:23 PM   #2
Rewards Points: 1,440
You need additional electrical know how and additional components to make heads or tails, correction make 120 volts or 240 volts AC out of 90 volts DC.
By the way there is no such thing as 3 phase DC, although DC does come in different qualities such as pure versus pulsating (unfiltered rectified AC).
Common consumer grade DC to AC converters (inverters) take 12 volts DC to create 120 volts AC. YOu cannot simply take one of those and hook it up to the 90 volt DC generator output.
Those generators had some specialized purpose. On board an airplane? On board a ship or yacht? Railway signaling?
Old 05-02-2012, 08:06 PM   #3
they were used by a cable company to run some transformers or ?? should i buy them or how much would it cost to convert them? im guessing the motors are worth 100.00 for a go cart but really need a cpl of generators.
it did say 3 ph on some and single ph on other data tags
Old 05-02-2012, 08:28 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would see if you can get more information on these and make sure they are a voltage you can use before you buy them. They may also have many hours of use on them.
Best thing would be to post pictures of the tags and post them here.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-03-2012, 06:10 AM   #5
dmxtothemax's Avatar
Rewards Points: 5,100
Transformers dont run on DC !
They only work on AC !
I have never seen a three phase DC genny !
Unless it is a three phase AC alternator with built in rectifiers
to provide a DC output.
If so, you might be able to tap off before the rectifiers
and get AC.
You need to do some investigation.
perhaps search online for specifications.
Or post pictures of the name plates with the spec's.
dmxtothemax is offline   Reply With Quote
Old 05-03-2012, 08:57 AM   #6
Experienced
Jackofall1's Avatar
As for the electrical portion I would follow the previous recommendations, as for the running those engines on propane, if they were originally rigged for NG, you will have purchase a conversion kit for that as well.
NG has a approximatly 1/3 of the btu's/ft3 as propane, so a suitably sized regulator and orfice would have to be used to convert to propane.
Mark
Old 05-03-2012, 09:27 AM   #7
I doubt it is a DC generator they are inefficient to make so almost all create AC power and convert it to DC. Many times they do both. Some of the telco backup systems have UPS built in or directly run on DC but it is mostly 48 volts.
Unless you see it stated that it outputs 240/120 volts it is not going to be real useful. You will find that a lot of 3 phase power runs voltages like 208 or 277. Changing these voltages is much tougher than just the phase issue.
bill01 is offline   Reply With Quote
Old 05-03-2012, 10:36 AM   #8
I=E/R
a7ecorsair's Avatar
Why don't you post a link so we can see what you've found.
a7ecorsair is offline   Reply With Quote
Generac Generators sbkim Electrical 5 05-02-2012 06:23 PM
Generac Transfer Switch Wiring diesel_farmer Electrical 1 12-13-2011 08:31 PM
Generac 10KW generator and Generac RTS12EZA1 transfer switch. exhdo1 Electrical 8 11-30-2011 03:33 PM
Generac residential generator PAbugman Electrical 13 11-21-2011 09:48 AM
Standby Generators JKE General DIY Discussions 5 06-15-2009 12:09 PM
