Should I Add An Electrical Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 07:29 PM   #1
Rewards Points: 260
Should I add an electrical box?
I have a small florescent light in my kitchen. I am going to replace it because the cover is broken. I noticed they did not have an electrical box behind it. It is just attached with butterfly anchors. I'm guessing it doesn't have a box because the electrical connections are made inside the light fixture. I'm debating on whether to replace it with a similar light or buy a vanity type light. Should I add a new work electrical box?
bluefitness is offline   Reply With Quote
Old 12-09-2008, 07:45 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You could use an old work box or if you have access, a new work box. I would not install one unless it is needed for the new fixture.
Old 12-09-2008, 09:01 PM   #3
Unless the new fixture completly encloses the wire splices like the original one did, you need to add a Jbox. Splices need to be contained in a fire resistant enclosure because they are the weak point in the system.
If the wirenut splice becomes loose it will arc, spark and cause a fire. If this happens, you want to contain it.
220/221 is offline   Reply With Quote
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
