-   -   Should I add an electrical box? (http://www.diychatroom.com/f18/should-i-add-electrical-box-33491/)
bluefitness 12-09-2008 06:29 PM
I have a small florescent light in my kitchen. I am going to replace it because the cover is broken. I noticed they did not have an electrical box behind it. It is just attached with butterfly anchors. I'm guessing it doesn't have a box because the electrical connections are made inside the light fixture. I'm debating on whether to replace it with a similar light or buy a vanity type light. Should I add a new work electrical box?
nap 12-09-2008 06:45 PM
You could use an old work box or if you have access, a new work box. I would not install one unless it is needed for the new fixture.
220/221 12-09-2008 08:01 PM
Unless the new fixture completly encloses the wire splices like the original one did, you need to add a Jbox. Splices need to be contained in a fire resistant enclosure because they are the weak point in the system.
If the wirenut splice becomes loose it will arc, spark and cause a fire. If this happens, you want to contain it.
