Should GFCI Have Triggered In This Scenario - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 08:45 AM   #1
Rewards Points: 70
Should GFCI have triggered in this scenario
Cutting a galvanized pipe in a home that had been diconnected further down the line several weeks ago. Assumned by now all if any water would have been gone when we drained it.
But there was some remaining water in the pipe where we were cutting.
Should the GFCI that we were plugged into have triggered?
If yes and obviously it did not, what do we need to look at?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-29-2012, 09:01 AM   #2
Rewards Points: 13,746
Why would it have tripped?
Unless water flooded into the tool the GFI could careless what you were cutting.
A small amount on the outside of the tool or on the blades not going to trip it.
Old 11-29-2012, 09:03 AM   #3
Rewards Points: 70
Novice assumption that, that is what a GFCI is for.
Thanks.
Old 11-29-2012, 09:13 AM   #4
http://home.howstuffworks.com/question117.htm
digitalplumber (11-29-2012)
Old 11-29-2012, 09:15 AM   #5
Rewards Points: 70
Originally Posted by joecaption View Post
I actually had read that after my post and before your initial response.
Old 11-29-2012, 09:45 AM   #6
Rewards Points: 1,514
The ground fault circuit interrupter trips when electricity has found a path back to the source other than via the neutral wire that accompanies the hot wire (and possibly through your body and with or without the help of water). Such a found and unintended path is referred to as a ground fault when it involves the earth or a grounded object or the ground wire (if any) that accompanies the hot and neutral wires of the circuit.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
Old 11-29-2012, 04:44 PM   #7
Master Electrician
Rewards Points: 3,874
I've encountered untripped GFCI's immersed in water. No current differential, no trip.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
stickboy1375 (11-29-2012)
Old 11-29-2012, 04:46 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Exactly. you can easily drop a hair dryer into a bucket of water and it simply will not trip the GFCI...
Another GFCI Question Jzone99 Electrical 5 09-16-2012 01:56 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
Can you test a non GFCI plug with a GFCI tester? DIYguy2000 Electrical 3 01-16-2012 06:49 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
