Should A Dryer Be 10 Gauge Wire & Range 8/3? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2008, 08:26 PM   #1
Rewards Points: 150
Should a dryer be 10 gauge wire & range 8/3?
I am getting ready to run the wires for my clothes dryer and my range. I was told by my electrician friend to use 10/3 for the dryer and 8/3 for the range. Is this correct? I thought 6/3 would be correct for a range. I am not sure why I think that. Any info would be appreciated. Thanks.
twilightcall is offline   Reply With Quote
Old 07-02-2008, 09:06 PM   #2
Licensed Pro
The 10/3 is pretty much standard for residential dryers. The 8/3 is the minimum size for a range. It's not that much more to go ahead and run the 6/3, so I would advise that.
Old 07-02-2008, 09:19 PM   #3
Electrician
#8 AWG is pretty common for ranges, but you can get burned, ( no pun intended) especially if using NM type cable, so if you plan on buying some fancy range, might want to invest now and install #6 AWG.
chris75 is offline   Reply With Quote
Old 07-02-2008, 09:19 PM   #4
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
the range depends on if you are running expensive copper or cheaper aluminum wire. copper you need 8 gauge as stated but if you go with aluminum you will have to run atleast 6 gauge.
Pudge565 is offline   Reply With Quote
Old 07-03-2008, 07:10 AM   #5
Rewards Points: 150
I bought 8/3 Romex, 600V Copper wire. It was around $2.00 per foot I think. Thanks Again for the info. I appreciate it. I wonder if Home Depot will take this back and let me put it towards some 6/3? THanks Again.
Old 07-03-2008, 07:14 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
For a range, I'd take the copper back and get some #6 AL SER.
wirenut1110 is offline   Reply With Quote
Old 07-03-2008, 07:26 AM   #7
I thought Alum wire wire was outlawed except for service drops.
BillyD is offline   Reply With Quote
Old 07-03-2008, 07:29 AM   #8
Rewards Points: 510
Not sure about other locations in the US, but I use it all day long.Most people can't afford copper anymore
10 gauge vs 12 gauge wire for 30 amp line hsdude1992 Electrical 10 08-19-2015 02:43 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
direct wire a range j1mw3b Electrical 7 02-16-2008 03:40 PM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 01:55 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
