-   -   Should a dryer be 10 gauge wire & range 8/3? (http://www.diychatroom.com/f18/should-dryer-10-gauge-wire-range-8-3-a-23100/)
twilightcall 07-02-2008 07:26 PM
I am getting ready to run the wires for my clothes dryer and my range. I was told by my electrician friend to use 10/3 for the dryer and 8/3 for the range. Is this correct? I thought 6/3 would be correct for a range. I am not sure why I think that. Any info would be appreciated. Thanks.
HouseHelper 07-02-2008 08:06 PM
The 10/3 is pretty much standard for residential dryers. The 8/3 is the minimum size for a range. It's not that much more to go ahead and run the 6/3, so I would advise that.
chris75 07-02-2008 08:19 PM
#8 AWG is pretty common for ranges, but you can get burned, ( no pun intended) especially if using NM type cable, so if you plan on buying some fancy range, might want to invest now and install #6 AWG.
Pudge565 07-02-2008 08:19 PM
the range depends on if you are running expensive copper or cheaper aluminum wire. copper you need 8 gauge as stated but if you go with aluminum you will have to run atleast 6 gauge.
twilightcall 07-03-2008 06:10 AM
I bought 8/3 Romex, 600V Copper wire. It was around $2.00 per foot I think. Thanks Again for the info. I appreciate it. I wonder if Home Depot will take this back and let me put it towards some 6/3? THanks Again.
wirenut1110 07-03-2008 06:14 AM
For a range, I'd take the copper back and get some #6 AL SER.
BillyD 07-03-2008 06:26 AM
I thought Alum wire wire was outlawed except for service drops.
wirenut1110 07-03-2008 06:29 AM
Not sure about other locations in the US, but I use it all day long.Most people can't afford copper anymore
