Should AFCI Trip Before GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 09:16 AM   #1
Rewards Points: 344
Should AFCI trip before GFCI?
The way my house is wired is every outdoor outlet is fed from the adjacent room and each one is a separate GFCI. When I installed a whole-house generator last summer (derecho) I swapped out some of the breakers in the transfer switch for AFCI for appropriate places.
One of these places is a downstairs bathroom which also has an outdoor outlet with GFCI. I was doing some work in my crawlspace and had brought an extra CFL drop light in with me plugged into that GFCI. Somehow I managed to break the CFL. So I went a got a replacement and still had no light. Checked the GFCI and had no power. Turns out the AFCI had tripped.
Should the GFCI have tripped first? I an really only concerned because this GFCI is near the pool and I want to make sure it is working as it should.
So far this is the first time I have had an AFCI trip. I have read about nuisance tripping but so far I have not experienced it.
herdfan is offline   Reply With Quote
Old 03-18-2013, 09:20 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
In that case, I would have thought the AFCI would trip.
Bathrooms are not required to have AFCI protection.
jbfan is online now   Reply With Quote
Old 03-18-2013, 09:44 AM   #3
Rewards Points: 344
I know, but the jackleg that wired this house placed the bathroom on the same circuit as an adjacent bedroom's closet.
Old 03-18-2013, 12:51 PM   #4
Licensed electrician
Rewards Points: 1,036
A GFI and an AFCI are looking for different reasons to trip. A ground fault can exist without an arc or you can have arcing without a ground fault.
If you want to see if the GFI is working push the test button. Did the power go off?
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Kyle_in_rure (03-18-2013), rjniles (03-18-2013)
Old 03-18-2013, 01:22 PM   #5
Imagine two people standing near you. You tell one to raise his hand when you yell "electrocute" and you tell the other to raise his hand when you yell "spark".
Each will only raise his hand when you yell the appropriate word.
Same with AFCI's (detects sparks - cause of fires).
GFCI's detect someone being shocked and quickly shut off power to prevent that.
Circuit breakers and fuses detect too much electricity being used (wires can get hot and cause a fire) and shut off the electricity before that can happen.
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
mpoulton (03-18-2013)
Old 03-18-2013, 02:06 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,860
AFCI's do detect ground faults, but at a higher trip level than GFCIs (roughly 30mA instead of 5mA). The intent is to detect ground faults that might cause a fire, not to instantly stop an electrocution in progress. The main function of an AFCI is to detect current waveform characteristics that look like an arcing fault, and apparently your light breakage tricked the AFCI into thinking that's what was happening.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
afci trips before gfci????????? jeremywj Electrical 7 08-01-2012 08:04 PM
Puzzled with AFCI nuisance trip ravi Electrical 11 06-06-2011 06:27 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
A few questions regarding GFCI AND AFCI protection CowboyAndy Electrical 5 03-10-2008 04:20 PM
