Shorted Ceiling Housing - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 02:00 PM   #1
I was replacing a ceiling fixture and idiotically to turn the power off. While the wires were live,the black and white wire touched the fixture mounting bracket and there was a loud spark. After turning the power off and installing the light correctly and turning the power back on, the light will not work. Are there any solutions?
Michael19g is offline   Reply With Quote
Old 03-06-2013, 02:13 PM   #2
Rewards Points: 34
Have you testded the black conductor so see if there's power going to it?
djlandkpl is offline   Reply With Quote
Old 03-06-2013, 02:20 PM   #3
I have, there is no power going to it. I have also cut and stripped the black and white wires.
Old 03-06-2013, 02:29 PM   #4
Did you check the breaker?
motorhead is offline   Reply With Quote
Old 03-06-2013, 02:31 PM   #5
Rewards Points: 34
Did you also check the feed side of the switch, if there is one?
Old 03-06-2013, 02:42 PM   #6
The breaker is on, if that is what you're referring to.
Old 03-06-2013, 02:42 PM   #7
Sorry, what is feed side?
Old 03-06-2013, 02:45 PM   #8
Rewards Points: 34
It's the hot (black) conductor that goes from the breaker to the switch. If the breaker is on, there should be power at the wall switch.
Old 03-06-2013, 02:47 PM   #9
I have not checked. If there is power there and none at the housing, would the wire from switch to the housing need to be replaced?
Old 03-06-2013, 02:51 PM   #10
Rewards Points: 34
If you find power there, my next step would be to rule out the switch. Turn off the breaker. Remove the conductors from the switch and connect them. Turn the breaker back on and see if your light works. If it doesn't check the light box to see if any of the conductors have power.
What are you using to check for power?
Old 03-06-2013, 02:55 PM   #11
A standard multimeter. There is no power from the conductors at the light box, I have checked.
Old 03-06-2013, 02:57 PM   #12
Rewards Points: 34
Is there a light switch (aside from the breaker) that controls the ceiling fixture?
Old 03-06-2013, 02:58 PM   #13
Yes the breaker connects to a light switch that connects to the light housing.
Old 03-06-2013, 03:00 PM   #14
Rewards Points: 34
First check the box that the light switch is in to see if there is power there.
Next step would be to rule out the switch. Turn off the breaker. Remove the conductors from the switch and connect them. Turn the breaker back on and see if your light works. If it doesn't check the light box to see if any of the conductors have power.
Old 03-06-2013, 03:03 PM   #15
eastcoastsparky's Avatar
Rewards Points: 150
Take the wires off the switch and wirenut them together then turn breaker back on and see if it comes on. Also with the switch disconnected put your meter in continuity mode, put probes on switch screws, flip switch, if it is good you will have continuity
eastcoastsparky is offline   Reply With Quote
Tags
ceiling fixture , electrical , housing , short circuit
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
