Originally Posted by Gigs
That ground that is coiled around the other grounds... does it go up into the nut or is it just twisted? If it doesn't go in the nut that's technically a violation.
I'm pretty sure that wire goes into the nut. It's not like me to effectively have a loose wire around.
I think what happened was that ground was a loose pigtail, and when I started twisting the nut, it started twisting around the wires that were anchored in the NM cable held firmly in place by the cable holder thingys. After wards, the free end was was then placed in the 2nd nut. I'm aslo pretty sure that that pigtail links the ground for the 20amp circuit to the ground for the 15amp circuit.
