Old 03-28-2005, 12:33 AM   #1
Short Wires
I NEED TO UPDATE MY ELECTRICAL PANEL TO 220A SERVICE. I FIND THAT SOME OF MY NEUTRAL AND GROUND WIRES ARE A BIT SHORT OF REACHING THE GROUNDING BAR. HOW DO I EXTEND THESE WIRES? CAN I ADD PIG TAILS TO EACH WIRE, USING WIRE NUTS?
sensen is offline   Reply With Quote
Old 03-28-2005, 05:50 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Short Wires
I am NOT a pro licensed electrician - and please wait until one or more confirms this - but I believe that the preliminary answer is yes, you can pigtail with the same size wire in this situation.
Also, you can double-check with your Building Inspection Department for local code on what is acceptable. They should be permitting and inspecting this anyway.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-28-2005, 12:19 PM   #3
Electrical Contractor
Short Wires
Yes. You can add wire by using wire nuts and extending to the neutral and ground bars. Make sure you use the same size wire and only 1 per screw and nut
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-01-2005, 01:36 PM   #4
Short Wires
Mike and Jbfan, thank you for the advice.
price for hooking up panel wires apeman76 Electrical 7 08-14-2007 03:04 AM
Running wires mt232 Electrical 4 03-22-2007 09:02 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
I caused a short in one room - now what? taychas Electrical 6 11-08-2006 05:02 PM
lighting lead wires tommygun32 Electrical 1 03-05-2006 11:10 AM
