-   -   Short Wires (http://www.diychatroom.com/f18/short-wires-475/)
sensen 03-27-2005 11:33 PM
Short Wires
I NEED TO UPDATE MY ELECTRICAL PANEL TO 220A SERVICE. I FIND THAT SOME OF MY NEUTRAL AND GROUND WIRES ARE A BIT SHORT OF REACHING THE GROUNDING BAR. HOW DO I EXTEND THESE WIRES? CAN I ADD PIG TAILS TO EACH WIRE, USING WIRE NUTS?
Mike Swearingen 03-28-2005 04:50 AM
I am NOT a pro licensed electrician - and please wait until one or more confirms this - but I believe that the preliminary answer is yes, you can pigtail with the same size wire in this situation.
Also, you can double-check with your Building Inspection Department for local code on what is acceptable. They should be permitting and inspecting this anyway.
Good Luck!
Mike
jbfan 03-28-2005 11:19 AM
Yes. You can add wire by using wire nuts and extending to the neutral and ground bars. Make sure you use the same size wire and only 1 per screw and nut
sensen 04-01-2005 12:36 PM
short wires
Mike and Jbfan, thank you for the advice.
