08-11-2012, 04:23 PM
#1
Short Wires
I NEED TO UPDATE MY ELECTRICAL PANEL. I FIND THAT SOME OF MY NEUTRAL AND GROUND AND HOT WIRES ARE A BIT SHORT OF REACHING THE GROUNDING BAR AND FOR THE BREAKERS. HOW DO I EXTEND THESE WIRES? CAN I ADD PIG TAILS TO EACH WIRE, USING WIRE NUTS?
Thanks in advance for any help or reply
08-11-2012, 04:28 PM
#2
Civil Engineer
Short Wires
You can pigtail in the panel using wire nuts, however an alternative strategy that may be better is to add a junction box outside the panel with perhaps an outlet, and run a new cable into the panel from there.
08-11-2012, 04:50 PM
#3
E2 Electrician
Short Wires
Just splice them in the panel... simple and effective.
08-11-2012, 05:03 PM
#4
A "Handy Husband"
Short Wires
If you are in the USA.
Coastal South Carolina
08-11-2012, 05:05 PM
#5
E2 Electrician
Short Wires
Well, dont leave me hanging... embrace my quest for knowledge and spill the beans already.
08-11-2012, 06:24 PM
#6
Licensed electrician
Short Wires
In Canada the CEC does not allow splices in a panel.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
08-11-2012, 06:26 PM
#7
E2 Electrician
Short Wires
Sucks to be them.
The Following User Says Thank You to stickboy1375 For This Useful Post:
08-11-2012, 06:47 PM
#8
Short Wires
Thanks every one for your help and replies.
08-11-2012, 08:29 PM
#9
JOATMON
Short Wires
And thank you for finding the caps lock key.....
Good luck
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
08-11-2012, 10:21 PM
#10
Lic Electrical Inspector
Short Wires
If you are replacing the panel look into Cutler Hammer. They have a new panel intended for replacements. It has a ground/neutral bar at the top of the panel.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
08-11-2012, 10:33 PM
#11
" Euro " electrician
Short Wires
Electures.,
IIRC they are called Renovation panels and some of them only have 5 blocks that you can able tie the conductor in ( I used 2 of them and they are ok to me ) and some models the tub width is narrower than standard tub what we are used to it.
Merci,
Marc
08-12-2012, 01:30 AM
#12
Master Electrician
Short Wires
Pretty sure we're allowed panel spliced. Not on feeders though with some exceptions. I know at one point you were only allowed two in a tub but from what I recall as long as box fill rules are applied its alright.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
08-13-2012, 09:42 PM
#13
Short Wires
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
