Short Wires
I NEED TO UPDATE MY ELECTRICAL PANEL. I FIND THAT SOME OF MY NEUTRAL AND GROUND AND HOT WIRES ARE A BIT SHORT OF REACHING THE GROUNDING BAR AND FOR THE BREAKERS. HOW DO I EXTEND THESE WIRES? CAN I ADD PIG TAILS TO EACH WIRE, USING WIRE NUTS?
Thanks in advance for any help or reply |
You can pigtail in the panel using wire nuts, however an alternative strategy that may be better is to add a junction box outside the panel with perhaps an outlet, and run a new cable into the panel from there.
Just splice them in the panel... simple and effective.
In Canada the CEC does not allow splices in a panel.
Thanks every one for your help and replies.
And thank you for finding the caps lock key.....
Good luck |
If you are replacing the panel look into Cutler Hammer. They have a new panel intended for replacements. It has a ground/neutral bar at the top of the panel.
Electures., IIRC they are called Renovation panels and some of them only have 5 blocks that you can able tie the conductor in ( I used 2 of them and they are ok to me ) and some models the tub width is narrower than standard tub what we are used to it. Merci, Marc |
Pretty sure we're allowed panel spliced. Not on feeders though with some exceptions. I know at one point you were only allowed two in a tub but from what I recall as long as box fill rules are applied its alright.
| All times are GMT -4. The time now is 11:31 AM. |
