#1 |
Short wire syndrome and bonding
Two NM cables enter a switch box. The box is being replaced with a 2-gang metal box for an additional switch, along with a third cable. Both bonding/grounding wires in the original NM cables were cut short by the original installer. There is not enough length to connect the two original bonding/grounding wires to the third new one, nor is there additional cable length in the wall cavity to pull more through.
Does the NEC allow the following solution?: 1. Land the two original bonding/grounding wires beneath two separate bonding/grounding screws. 2. Land a pig-tail beneath a third bonding screw. 3. Wire-nut the pig-tail, the new bonding/grounding wire, and the bonding leads from the switches. Thanks. |
#2 |
Average Joe/ex-Navy IC3
Through in another junction box, or replace that run of wire and call it done.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Is there anything showing of the ground wires coming out of the cables.
This is what I would do: Make up 8 inch (bare) pigtails for each. Sand the exposed ends and also about 2 inches of the pigtails. Make a tight spiral on one end of each pigtail to slip over the end of the ground wire remaining. Then solder it on. These pigtails have now become extensions of the short ground wires. But before I try this, there would have to be at least an inch of the original wire showing. About half inch to slide the spiraled pigtail end over and the other portion to clip a pair of pliers onto to act as a heat sink so as not to melt the conductors further back inside the NM cable.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 01-02-2013 at 03:09 PM. |
#4 |
Licensed Pro
If there is enough bare wire on the original cables to go to a screw, then there would be enough to use a Wago or Ideal push-on connector. Use that to connect the old and new ground wires.
"Life is hard. Life is harder when you're stupid." John Wayne |
#5 | |
Lic Electrical Inspector
Short wire syndrome and bondingQuote:
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
| The Following User Says Thank You to electures For This Useful Post: | jlmran (01-02-2013) |
| Display Modes | |
