Short Circuit. Reset The Breaker, But No Power - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 03:06 AM   #1
short circuit. reset the breaker, but no power
I tried to replace the receptacle outlet without turn off the breaker (bad idea). The cutter accidently touch the ground while I try to cut the hot wire. At the moment they touched, there is a loud popping sound from the outlet. I reset every breaker (because the panel is poorly label) but there is still no power for that outlet. Any one know what might cause no power from the outlet with the stupid mistake I made?
bp91708 is offline   Reply With Quote
Old 03-18-2011, 07:41 AM   #2
Learning by Doing
Leah Frances's Avatar
Sometimes lessons are learned the hard way. Go to the blackboard and write 50 times: I will not work on Hot circuits.
You are going to have to be a detective and start hunting.
- new outlet, right?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-18-2011, 08:03 AM   #3
Licensed electrician
Rewards Points: 1,296
Some breakers are not all that far out of position when tripped. Run your hand down the row and feel to see if they line up.
Old 03-18-2011, 08:27 AM   #4
joed's Avatar
Rewards Points: 12,028
Some brands of breakers require you to turn them to off to reset them.
Old 03-18-2011, 09:04 AM   #5
Coatings Nerd
Thats how I find the breaker. I cant be bothered looking around the box for the right one. I just touch the black and white together until it trips and I hear the "pop". Im a hack though
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-18-2011, 09:18 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
I hope you don't have one of those never trip breakers like FP.
Old 03-18-2011, 09:25 AM   #7
Coatings Nerd
Nope, mine are the "always trip" kind
Old 03-18-2011, 09:40 AM   #8
Experienced
Jackofall1's Avatar
Is the circuit you are adding on to protected by a GFCI? in which case you could reset the breaker but the GFCI will also need resetting.
Mark
Old 03-18-2011, 10:15 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits I will not work on live circuits
Teacher...I've got a cramp....can I stop now ?
Kyle
Old 03-18-2011, 10:35 AM   #10
Experienced
Jackofall1's Avatar
Go stand in the corner and don't move
Old 03-18-2011, 11:07 AM   #11
Electrician
SD515's Avatar
Rewards Points: 504
Kyle
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
No power to all outlets on circuit. noloawarfare Electrical 4 05-01-2010 05:41 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
