Short Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 06:10 PM   #1
Rewards Points: 77
short circuit question
i was changing a switch and when i was using a neon tester between the metal box and the hot wire screw, the tester probe came in contact with the metal strip that goes around the switch(decor switch) and it popped and sparked a little, the wires look fine just some scorching and a burn mark on the switch, i put a new switch and it works fine. there should be no problems down the line from my little accident correct??
bryan1282 is offline   Reply With Quote
Old 10-05-2009, 06:14 PM   #2
300zx's Avatar
Post
Yes if the wires look fine and you put a new switch in there will be no problem
300zx is offline   Reply With Quote
Circuit Panel Question erinuncool Electrical 18 10-07-2009 04:18 PM
Question about a circuit and wiring..... whowadat Electrical 5 01-14-2009 05:59 PM
another arc fault question.... steve1234 Electrical 16 06-12-2008 12:17 PM
Attic fan and skylights on same circuit ok? shadango Electrical 7 06-09-2008 03:50 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
