Short Circuit But Breaker Does Not Trip - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 08:54 PM   #1
Short Circuit but Breaker does not trip
My wife plugged in her vacuum soon as she turned it on the power went out to the circuit. My first intuition is to check the breakers to see if it tripped. I take a look and no breakers are tripped (I have the old push button breakers) but the entire circuit went out (all the outlets in the room and some random lights). I take out my meter and check the plug that my wife plugged into, no power but I have an infinite short between the hot and neutral. the same goes for all of the other plugs on the circuit. I take out the outlet to see if the short occured there, nope it looks fine. I did find a junction box in the cellar that is feeding that circuit, I pull the wires apart in the box and narrow it down to one of the wires that has a short between the hot and neutral. I check the plugs upstairs again, no infinite short at any of them, however I am reading 53 ohms between the hot an neutral. How is it that I have a short but the breaker does not trip and should I be reading 53 ohms?
Thank you,
Ryan
vino82 is offline   Reply With Quote
Old 01-28-2010, 09:25 PM   #2
joed's Avatar
Rewards Points: 12,902
Any device plugged into the circuit will show as short. You are looking in the wrong place. If the breaker is not tripped then you need to look for an open not a short circuit.
Old 01-29-2010, 06:57 AM   #3
Is it correct to say the short im reading could be the bulbs that are in the lights attached to the circuit? For this circuit to be working fine for weeks now (we just moved in) and suddenly it going out is peculiar. If there is an open somewhere down the line, how is it that plugging in the vacuum and turning it on suddenly cause an open in the circuit somewhere else other than behind the outlet which she plugged into (which has only one wire)?
Thank you for the advice,
Ryan
Old 01-29-2010, 07:05 AM   #4
Licensed Pro
Ryan
If there was a loose connection somewhere in the circuit, the surge from the vaccum could have caused the connection to open. If the entire circuit is out, suspect a loose connection in the panel.... most likely on the neutral (white) wire.
Old 01-29-2010, 09:14 AM   #5
joed's Avatar
Vacuum is a high current device. It is one of the most common devices to cause a connection to go open. If the breaker is not tripped you do not have a short. You are reading the light bulbs filiments or something else plugged into the circuit.
Old 01-29-2010, 11:05 AM   #6
You all have been very helpful, once Im home I am going to check for a loose neutral in the panel. Is it possible that there may be a faulty splice in a junction box that could have opened upon starting of the Vacuum?
Thank you,
Ryan
Old 01-29-2010, 12:54 PM   #7
Licensed Pro
Thank you,
Ryan
The "open splice" could be anywhere... the fact the the entire circuit is affected means it has occured either at the panel or between the panel and the first outlet.
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 09:47 AM
Insulation around a electrical circuit breaker box terpsing Electrical 4 02-03-2009 03:08 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 12:52 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
