Short Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 04:05 PM   #1
Short circuit
I am wiring from the breaker to the first outlet, then to a second outlet, then up to first light, then a second light, then a third light and then to the switch. When the breaker is turned on, even though the switch is in the off position, the lights work; then when I flip the switch to "On", the breaker trips.
What am I doing wrong? Thanks.
threebubbas is offline   Reply With Quote
Old 07-20-2011, 04:16 PM   #2
I=E/R
a7ecorsair's Avatar
You have a neutral connected to the switch circuit at some place in the string.
a7ecorsair is offline   Reply With Quote
Old 07-20-2011, 04:18 PM   #3
Licensed electrician
Rewards Points: 1,872
You would need a 3 wire cable between the lights and switches instead of the 2 wire cable you have.
Old 07-20-2011, 04:29 PM   #4
I=E/R
a7ecorsair's Avatar
To be more specific, as Jim said, you need 14-3, if this is the size wire you are using, from the first fixture to the next two fixtures.
You will carry the black through all the fixtures without connection to anything. You will connect the red to the lights.
At the last fixture you will connect the white that goes to the switch to the black that was carried through.
You will connect the black coming from the switch to the red wire.
The white in the 14-3 will be carried through and connect to each light.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Troubleshooting strange brownout effect on one circuit BigFZ Electrical 5 10-26-2010 09:08 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
