Old 10-09-2005, 01:14 PM   #1
tryit
Shop Power & Lighting
I am converting a garage into a woodworking shop. I need to add a power mold strip behind a work bench. The run will be 7 feet long and will be used for typical hand tools, vacum, strip light, battery charger and yes, a television.
I am assuming a 20 amp breaker from the service panel which is within 5 feet of the beginning of the run. Should this be GFI? Any other advice? Is there a site providing a diagram of any sort. Thanks !!!
schoondogg is offline   Reply With Quote
Old 10-09-2005, 02:15 PM   #2
Try this. http://www.selfhelpandmore.com/homew...sory/index.htm
K2eoj is offline   Reply With Quote
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
wiring for recessed lighting krw3153 Electrical 1 10-04-2005 02:39 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
