Shocking Amp Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 10:17 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
shocking amp question
No really, it's a question about shocks and amps.
Ok so from my understanding it takes about 1 amp, maybe even less to kill. So say you get a shock between the two terminals of a socket since you touched both screws or something, what exactly determines how many amps will go through you?
Now whether said socket is rated at 15, 20 or even 50 amps, I can't see that making any difference, since the rating just means that if an appliance draws that amount, it trips the breaker. Voltage is what is pushed out, amps are just what are "taken" if that makes sense. I've seen people think that you can "blow" an appliance if you give it too much amps, but, appliances are not given amps, they're given voltage, then they draw whatever amps they need. At least that's my understanding of it.
Now in the case of a series shock, such as turning off a light switch and touching the two terminals, then you would complete the circuit and get more amps through you right? So is this a more dangerous type of shock? Guess this depends on the load too, like a incad light vs a motor, might be different.
The only thing I can think of is that skin creates a resistance, then it increases the amperage so like depending on where you are shocked the resistance is greater, thus more voltage. So from finger to finger = less amps then from one arm to the leg. Water seems to give a better shock too. I noticed this when playing with about 13 9 volt batteries to see how many it takes to get a shock.
Old 01-19-2010, 10:40 PM   #2
Civil Engineer
Rewards Points: 4,530
The basic equation is I = V/R where I is the current in amps, V is the voltage in volts, and R is the resistance in ohms. This equation is correct for direct current, and for purposes of your question is correct for alternating current as well. So if your finger has a resistance of say 1000 ohms, and the voltage is 120 volts, and you dead short across the hots of an outlet, you will draw about 0.125 amps. A potentially lethal amperage at 120 volts AC is somewhere around 100 milliamps (that is one tenth of an amp)
However, that will only kill you if the circuit is connected across your heart, causing an arythmia. This could occur if one hand is touching a hot wire, and the other hand is grounded. The current that would flow would then be determined by the effective resistance of your body, which varies from somewhere around 1000 ohms if you are sweating to 100,000 ohms if you have dry skin. Note that the lethal ampacity varies depending on the frequency of the source, and whether it is AC or DC.
Daniel Holzman is online now   Reply With Quote
Old 01-19-2010, 10:49 PM   #3
Wire Chewer
Rewards Points: 46
Ah ok makes sense. I'm guessing how long you are exposed makes a difference too. I'm sure if I hold on to 120 long enough it will be harmful evne if I'm drawing few miliamps.
Guess the I = V/R explains why you don't feel a shock with very low voltage. For example a computer power supply gives out 12 volts, but it has a potential to give quite a few amps.
I remember getting a shock from arm to arm once and it was quite the kick compared to just a finger shock. Silly person wired the ground into the hot and I was holding the "grounded" wire box and reached for something that was grounded. Never trust other people's electrical since for them a bare copper wire may not mean the same as you.
Old 01-19-2010, 10:49 PM   #4
Shock current path...
http://vias.org/feee/safety_04.html
Billy_Bob is offline   Reply With Quote
Old 01-19-2010, 10:56 PM   #5
Inspector/Instructor
codeone's Avatar
Heres a chart that may help. Courtsey of IAEI.
codeone is offline   Reply With Quote
Old 01-20-2010, 08:32 AM   #6
Rewards Points: 1,418
You are most likely to get electrocuted if the path of the electricity goes past your heart or past your spinal column (nerve trunk), such as from the finger in one hand to the sole of your foot.
While dry skin has considerable resistance, salt water moisture including that in the sweat glands may result in a minute current flow starting and the skin and tissues in that vicinity get burned with more liquid (means of conduction) exposed which in turn lets the current flow increase.
Old 01-20-2010, 08:42 PM   #7
Also remember that any shock could be dangerous, regardless of how many milliamps are delivered. A relatively small shock could cause you you to flinch or move unexpectedly. Considering that most people working with electricity at some point find themselves on a ladder, a small shock could cause a fall. Anyone working with electricity, especially the DIYer, should work with the circuit de-energized! A friend of mine was changing a light switch in his kitchen. He got shocked which caused him to drop a set of pliers...of course they cracked his floor tile. A small price to pay, but a lesson learned. Turn the circuit off!
http://www.electriciansgangbox.com/blog
ElectGangBox is offline   Reply With Quote
Old 01-20-2010, 10:04 PM   #8
Wire Chewer
Rewards Points: 46
This is true, any time I've been shocked I've flinched and dropped anything I was holding. When I got my shock from arm to arm due to a badly "grounded" item (was hot!) I actually "jumped" back like 3 feet and dropped everything. It happened so fast, was like a flash. I was actually laughing for the next 15 minutes and it took at least half an hour for the sensation to go away. Had I been on a ladder I probably would not have been laughing!
I also noticed water makes the shock hurt way more.. I can't speak for 120vac as I've only gotten "Dry" shocks but at work we were messing around with lot of 9 volt batteries to see how many it takes to feel a shock. We were at 13 and I could only feel a sensation. I decided to see what happens if I lick my fingers. OUCH!
Old 01-20-2010, 10:10 PM   #9
Yeah, I still do not follow my own advice sometimes and it ends up biting me sometimes also! If you do get shocked with enough milliamps, your body actually burns from the inside out. Google "electrical burns" and look at some pics and vids. Pretty nasty stuff! Here is a good example...
http://www.osha.gov/SLTC/etools/cons...nts/burns.html
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
