Shocked While Touching Conduit?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2007, 07:31 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,290
Shocked while touching conduit??
I'm reworking some circuits in the basement. I was adding some new conduit for new lights and outlets for the basement. While I was putting the conduit together (no wires yet, but the conduit is attached to the panel), I was getting a slight shock. My wife was vacuuming upstairs using an unrelated outlet. When I asked her to change outlets, the problem went away. What caused this, is it just because she was using an ungrounded outlet?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-21-2007, 07:44 AM   #2
RippySkippy's Avatar
Could it have been a static shock? Not uncommon with vacuuming...and grounding wouldn't hurt.
RippySkippy is offline   Reply With Quote
Old 05-21-2007, 09:41 AM   #3
I have gas!
No it wasn't static, I could tell there was current flowing through me. Is this ungrounded outlet dangerous or is that just the nature of an ungrounded circuit?
Old 05-21-2007, 04:00 PM   #4
Well..anytime current flows through you, it isn't a good thing. Wish I knew what to tell you, but since I don't, I'll leave it with "talk to a pro, it could be dangerous."
Beren is offline   Reply With Quote
Old 05-21-2007, 07:26 PM   #5
I am going to guess that you have two problems.
One is a short from neutral to ground on the circuit that the vacume was on when you were shocked. Two is a loose neutral to ground bond in the panel.
the combination of the two caused the neutral currents to flow over the ground path and you.
this is something to be concerned about, and get fixed.
Master Electrician
jwhite is offline   Reply With Quote
Old 05-21-2007, 08:49 PM   #6
I have gas!
Thanks J, you nailed it.
Although the hoover doesn't have a ground. The outlet does. I pulled the cover off the panel and found the ground either broke off or was snipped off and was just tucked in under the fitting. The outlet had a bare ground so I think that it may have been touching the neutral screws of the outlet.
conduit around the swimming pool januwan Electrical 6 05-20-2007 09:14 PM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 09:35 PM
2" conduit and subpanels A.W.Davis Electrical 4 11-23-2006 09:23 PM
Basement Electrical- Flexible Conduit? H Thomas Electrical 2 04-20-2006 09:42 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
