Old 06-08-2011, 01:17 AM   #1
Shock in shower/ Utility Company Dumbfounded
The utility company just left after being here for 3 hours.
They looked in panel and everything was OK.
They pulled the meter and still had 2v on cast iron drain pipe to tub and surrounding waste pipes.
Then they drove another 8' ground rod and used new #4 solid copper to bond it to the panel ground to make sure it was good.
Tested again... Still 2 volts on pipes and tub.
Then they unhooked the transformer... Still 2 volts on pipe and tub.
And the kicker is there is continuity between the tub drain and the faucet knobs that are acting as the path to ground.
What on earth is going on here???
Does anyone have any idea?
The pipes are galvanized steel and cast iron. I know there is galvanic corrosion after 60 years, but enough to become a battery? The other thing is that the meter shows no DC voltage... only AC. Also, the charge does not disapate after shocking you. It remains right around 2 volts...
Is it OK to just drive another rod and run the ground from the waste pipe to that or is it OK to bond it to the cold water pipe either at the panel or jumper from the waste pipe to the closest cold water pipe?
Clearly this has nothing to do with the house power or the utility company.
Sierevello is offline   Reply With Quote
Old 06-08-2011, 01:26 AM   #2
" Euro " electrician
frenchelectrican's Avatar
I just reply in the other thread so read it there and again .,, Please get a electrician come in and assist you on this matter.
C'est la situation très sérieuse tout de suite.
( This is a very serious situation right now )
Merci,
Marc
Old 06-08-2011, 04:39 AM   #3
Electrical Contractor
kbsparky's Avatar
Are the water pipes directly bonded to the drain pipe? That usually eliminates any potential difference (e.g: VOLTAGE) between them.
Proper bonding is not accomplished by wrapping wires around the pipes. Listed bonding clamps must be utilized ...
-KB
Old 06-08-2011, 09:41 AM   #4
Lic Electrical Inspector
electures's Avatar
The utility companies use the earth as the return path to the generation station. This causes all types of stray currents to show up anywhere. Hence the reason for equipotential bonding grids around pools. Dairy farmers have known about this for years which is why the ramps into the milking barns have equipotential bonding grids installed in them. I think your problem may be effected by this some how.
Good luck!
electures is online now   Reply With Quote
Old 06-08-2011, 11:41 AM   #5
Do you have a utility pole or transmission line very close to this bathroom/your home? Electromagnetic fields are controversial.
diyorpay is offline   Reply With Quote
Old 06-08-2011, 12:55 PM   #6
Electromagician
Not so fast. Did they disconnect all the surrounding houses as well? If not the problem may be at a neighbors house and returning on your grounding or grounded conductor.
powerfactor is offline   Reply With Quote
Old 06-08-2011, 01:11 PM   #7
Electrician
SD515's Avatar
My suspicions too powerfactor.
Kyle
Old 06-08-2011, 01:31 PM   #8
Electromagician
This type of problem has even been found to travel on metal plumbing pipes, cablevision lines, gas lines or any other metal connection to the house.
Old 06-08-2011, 06:39 PM   #9
Can you disconnect the tub from the main ground,
Isolate it completely (plumb with plastic pipes)
Then give the tub its very own seperate ground rod.
This way it is not connectted to the system,
But it is still earthed !
Does the code permit this ?
dmxtothemax is offline   Reply With Quote
Old 06-08-2011, 11:35 PM   #10
I have no idea where you get that idea about get the tub on seperated ground rods that is conneries* .,,,,
I will not suggest to do this at all the only way you can slove it is do the proper bonding as I mention somewhere else in the fourm have a electrician to come out and assist you on this one there is not much leeway to screw around with it.
Merci,
Marc
* this word you will have to look it up yourself.
Old 06-09-2011, 01:05 AM   #11
Originally Posted by frenchelectrican View Post
...that is conneries*
Old 06-09-2011, 01:08 AM   #12
Learning by Doing
Leah Frances's Avatar
Originally Posted by sirsparksalot View Post
I googled it too.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following 2 Users Say Thank You to Leah Frances For This Useful Post:
drtbk4ever (06-09-2011), frenchelectrican (06-09-2011)
Old 06-09-2011, 02:08 AM   #13
Originally Posted by Leah Frances View Post
I googled it too.
I know both of you were little suprised with my reaction.
But I am sorry for saying this but some peoples have to understand the nature of electrique system that something you CAN not fool around for nothing.
And also the other reason why I was a little harsh due some people will come up some of the idea which we electricians will know they will not really get it thru in proper way.
dmxtothemax.,
Unforetally the question you asked in the fourm that is not a really safe situation as you are aware with the OP's issue going on as you may allready noted in couple other threads in this fourm.
again sorry if I was harsh on one comment but for safety for other peoples sake in the fourm I have to use the common sense what is safe et what not.,,
( I have see some crazy stuff in my 20+ years in my trade )
Merci,
Marc
Old 06-09-2011, 02:18 AM   #14
LOL, Marc, it's all good. We got a kick out of the fact that we actually Googled the word, and we now understand it completely :-)
The Following User Says Thank You to sirsparksalot For This Useful Post:
Old 06-09-2011, 06:17 AM   #15
Didnt he already say that it was properly bonded ?
And that the problem still exists ?
Perhaps another nearby instalation is not bonded correctly,
causing eddy currents.
Or just plain capacitive coupling.
It will be interesting to find out the true cause .
Shower stall installation mforeman1 Flooring 1 04-06-2011 08:39 AM
Bathroom Remodel aworkman General Discussion 17 03-05-2011 02:21 PM
Roofing Company Refuses to Quote for ... Dodah Roofing 11 06-03-2009 07:17 PM
HOW MUCH?? To have utility company install new pole? ehoez Electrical 3 06-26-2008 11:18 AM
