Shim An Electrical Box In Exterior Brick Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 10:27 AM   #1
Question
shim an electrical box in exterior brick wall?
Hi, all. I'm replacing an outdoor light and in the process I've loosened an electrical box that's mounted in an exterior brick wall. The mortar came loose around the box, so now the box is pretty loose. I know I could mix up some mortar and secure it that way, but I'm wondering if there's a non-wood shim or wedge that I could insert between the box and the adjacent bricks. Something that can expand with a threaded screw, same idea as a molly bolt? Just wondering. Thanks for any suggestions.
sometimes handy is offline   Reply With Quote
Old 09-07-2009, 10:45 AM   #2
Remodeling Contractor
use composite or plastic shims or just caulk with concrete polyurethane caulking.
Old 09-07-2009, 10:56 AM   #3
thanks, Bob. Do you know if those shims are sold in big-box retailer like HomeDepot, or only in a specialty store?
Old 09-07-2009, 11:07 AM   #4
300zx's Avatar
Post
They should have them http://www.lowes.com/lowes/lkn?actio...655&lpage=none
300zx is offline   Reply With Quote
Old 09-07-2009, 11:14 AM   #5
Smile
Many thanks!
You guys are the best. Thanks and enjoy what's left of Labor Day!
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 03:50 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
