Shielding Coax From Parallel Electrical Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 05:49 PM   #1
Shielding coax from parallel electrical wires
Hello all,
Longtime lurker, first time poster. I am doing a partial basement renovation (bathroom and bedroom) and intend to run coaxial cable (RG-6) to the new bedroom. My problem is that the only path that I have available to run the cable (along a structural I-beam that runs down the center of the house) is also the location of 2 or 3 NM electrical cables that take advantage of the same pathway. At present, the Romex and the coax run in parallel for approximately 20 feet. For various reasons, I cannot relocate either without dramatically increasing the scope and cost of this project.
Everything I've read says to keep coax 6-12 inches away from electrical cable. Since that is not possible in my case, is there any kind of additional shielding I can apply to the coax, or is there special coax manufactured for situations such as these?
Thanks for the consideration.
Rigel900 is offline   Reply With Quote
Old 07-03-2013, 06:03 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
If your coax shield is properly grounded to earth ground.....you will be fine....
Your ac power is 60Hz.....the coax signal is 100MHz to 1Ghz.......Even Chinese made video equipment will have a balun on the coax end....the 60hz will not get in.
Old 07-03-2013, 07:50 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
COAX is already shielded. 20' is not going to hurt anything.
Speedy Petey is online now   Reply With Quote
Multiple "pilot" wires for heaters at the electrical box. How to figure out which is hstraf Electrical 3 12-11-2012 09:57 PM
Electrical wires touching heating/air cond. tubes between joists yummy mummy Building & Construction 5 09-27-2007 05:59 PM
Electrical Wires and Shower Stall Burat Electrical 10 05-03-2007 09:49 AM
Running speaker wire parallel to electrical wire spyguy Electrical 3 02-21-2007 03:10 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
