Shethed Or Unsheathed Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 10:37 PM   #1
JLM
shethed or unsheathed cable?
I am running power about 180 feet to power a 60A subpanel in an outbuilding. I am expecting to use 2-2-2-4 AL. The run is underground for about 150', and the balance through crawlspace and basement to the panel. My question is: can I use a sheathed cable such as SEU in the conduit so I can simply continue (unconduited) under the house, or do I have to run URD in the conduit to a juction box and change to a sheathed cable to run under the building? Or can i run URD in the conduit under the house to the panel (this would be less preferred). Thanks
JLM is offline   Reply With Quote
Old 04-25-2012, 07:24 AM   #2
Code05's Avatar
Rewards Points: 1,104
No, you cannot use SEU underground in conduit.
You can either of your other 2 ideas.
Note, I am assuming that what you are calling URD is really dual rated USE/RHW.
True URD cable is not listed in the NEC and cannot be used by home owners.
Code05 is offline   Reply With Quote
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
