Sheetrocking Basement And Shorted Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 08:56 PM   #1
sheetrocking basement and shorted wires
vacumn stays on all the time. Why?
trusty is offline   Reply With Quote
Old 02-27-2012, 09:00 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Please explain a little more. It stays on sounds like a switch is stuck in the on position inside. Shorted out conductors fused themselves together. Probably needs a new switch.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following 2 Users Say Thank You to rrolleston For This Useful Post:
plummen (02-27-2012), trusty (02-27-2012)
Old 02-27-2012, 09:00 PM   #3
" Euro " electrician
frenchelectrican's Avatar
If you have central vaccum system then you have control circuit shorted so you will have to find out which one is shorted I know it will not be easy to find it.
The key issue is one of your screw hit the control wire[s] and shorted out.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
trusty (02-27-2012)
Old 02-27-2012, 09:01 PM   #4
Rewards Points: 582
ok turn off switch??? more info is needed...
Old 02-27-2012, 09:20 PM   #5
Rewards Points: 13,300
Sounds like you put a screw in the wall right where the switch wire is and the screw is completing the circut.
Going to have to remove the rock and replace the wire.
There was suppost to be nailing plates over any wires that were not drilled into the middle of the joist.
What length screws are you using?
Old 02-27-2012, 09:31 PM   #6
i think you hit the nail on the head. But I do not know which switch to replace. Can you elaborate.? you came to the same conclusion that I did but I am not familiar enough with the system
Old 02-27-2012, 09:39 PM   #7
It's the wire not the switch that needs to be replaced if there's a screw put through it.
Correct me if I'm wrong, but your post says your installing sheetrock. If so remove it so the wire can be replaced.
Old 02-27-2012, 10:12 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What's worse (maybe) is that i've never seen anyone run the low volt wire separate from the piping. Usually it is taped directly to the pipe. Sadly, if you hit the wire, i'm betting you hit the pipe too. Buy a vac pipe coupling while you're at it.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
ben's plumbing (02-28-2012)
