Shed Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 02:25 PM   #1
seansy59's Avatar
Rewards Points: 258
Shed Subpanel
Finally decided to bite the bullet and run a feed to the shed. Its approx 125-150ft away.
-Separate Neutral/Ground in 125a Sub Panel in shed with main breaker installed (DP 30a also)
-15amp breakers for the existing 14ga runs. GFCI outlet already installed on exterior.
-2 8ft ground rods with #10 THWN- Min 6ft apart- Below ground
-3/4" PVC Conduit 18" Deep
-80ft #10 4 Conductor (H1,H2,N,G) THWN Underground
-50ft 10/3 NM Splice in J-Box going to panel at house
-30amp 2 pole breaker in Main panel
All this sound kosher?
Questions:
1. Is #10 THWN suitable for the ground rods since that is the feeder size? Should it also be in conduit, or can it just run through a small hole in the floor outside?
2. What is an easy way to drive a ground rod without power tools? I heard a hole, water, and hammer is simple? LOL.........
seansy59 is offline   Reply With Quote
Old 01-21-2013, 04:31 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Seems like you got it. But 6 is what is used for ground rods and 4 if it's subject to damage. I always just get #4 stranded. Easy to bend and not too expensive.
You could always run another piece of conduit it's cheap enough if you want tv or phone out in the shed.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-21-2013, 05:48 PM   #3
seansy59's Avatar
Rewards Points: 258
Awesome......and thanks......
I will probably just get the #4 stranded. I only need 15ft. I'll sleeve it from the floor into the ground since I have some chew happy animals around here.
Good idea on the phone and cable! I'll run an Ethernet cable and a piece of coax.
Old 01-21-2013, 06:11 PM   #4
rrolleston's Avatar
They must be big if they can chew that wire. Also good idea to use MC cable there. My uncle had all his wire chewed up in his garage.
Old 01-21-2013, 06:42 PM   #5
seansy59's Avatar
Rewards Points: 258
LOL......it's only outside. The shed is completely sealed and closed up. I have a computer, stereo, TV and carpeting in there. Wiring is still done up along the top eve though away from the ground so its protected.
Old 01-21-2013, 07:15 PM   #6
Rewards Points: 160
Ground rod is optional, no? But obviously ground and neutral should not be bonded at the subpanel.
philS is offline   Reply With Quote
Old 01-21-2013, 07:18 PM   #7
jbfan's Avatar
Rewards Points: 420
Ground rods are not optional.
Old 01-21-2013, 08:33 PM   #8
Rewards Points: 160
So what's the rule - detached structure requires ground rod? In fact all my detached structures have been pump houses and I ground to the well casing. But clearly a subpanel within the same structure as the panel doesn't require a separate ground rod, though I'm under the impression that it's ok to install one if one wanted.
Old 01-21-2013, 08:35 PM   #9
rrolleston's Avatar
All sub panels in detached structures require ground rods and four wire feeds with separate neutral and ground.
Old 01-21-2013, 08:43 PM   #10
Rewards Points: 160
Thanks. That actually affects the cabin I'm in now. I've got a ground rod at the cabin already, left over from when the PV system and main panel were located there. Right now it's hooked only to the lightning rod. I'll run another line tomorrow form the ground rod to the subpanel.
What's the logic here? A backup against a fault in the ground wire? Added insurance against stray voltage effects?
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
running subpanel supply along shed ridge beam amakarevic Electrical 8 04-24-2016 05:10 PM
Shed subpanel BrandonD Electrical 21 10-14-2012 12:06 PM
running wire for 50A subpanel in a detached shed amakarevic Electrical 10 03-17-2011 05:04 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
