Sharing Inserts On Ground Bus Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 06:07 PM   #1
Rewards Points: 1,062
Question
sharing inserts on ground bus bar
is it OK that share an insert, provided, of course, that the second wire has enough width to get it? i ran out of inserts but need to ground my cable and phone connection.
thanks
Old 05-16-2012, 06:51 PM   #2
Licensed electrician
Rewards Points: 1,738
Neutrals cannot share a terminal in the bus bar. Ofter times 2 grounding conductors of the same size and material can share a hole.
Have you thought about adding a grounding bus. An intersystem bond would also work.
http://www.aifittings.com/catalog/gr...nding-bridges/
amakarevic (05-16-2012)
Old 05-16-2012, 10:03 PM   #3
kevinp22's Avatar
Rewards Points: 252
there is usually a sticker inside the box indicating the number and size of ground wires that may be inserted under a single terminal screw.
kevinp22 is offline   Reply With Quote
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 03:05 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
