Sharing Ground Bus Holes - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 11:40 PM   #1
Rewards Points: 1,062
Question
sharing ground bus holes
is it OK to share a grounding bus hole between two wires coming in?
thanks
Old 07-13-2011, 12:21 AM   #2
Rewards Points: 324
as long as they are both grounds and same gauge.also some panels allow and some don't.read the lable.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
amakarevic (07-13-2011)
Old 07-13-2011, 12:36 AM   #3
why do they have to be the same gauge ?
Old 07-13-2011, 12:38 AM   #4
Rewards Points: 324
if they are diff gauge,the smaller may not get tight.
Old 07-13-2011, 12:48 AM   #5
oh, OK. makes perfect sense.
Old 07-13-2011, 12:55 AM   #6
Rewards Points: 324
also only one neutral under a screw on neutral buss.
Tags
ground bar , grounding , grounding. electrical
Fake Ground at Panel Perry401 Electrical 28 05-25-2013 04:29 PM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
