Shared Neutral - Open??? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 09:47 PM   #1
Got some funky electrical gremlins on a couple of circuits, well more exactly two circuits that share a neutral. Seems to me like an open neutral issue. I properly get 240v between the red and black hot wires, but down around 110 between either the black or red and the white neutral. I get 10-20 volts between white and ground. So something is up. Back at the panel checking between the neutral bar and the breakers I get 120 on each breaker when they are on. About .5v when they are off. When I turn one breaker on I get 120v between it and the neutral and then about 18v between the on that is off and the neutral bar!! So obviously something is wrong. Any idea what I can check or how to track down this issue? As best I can tell I have found the box that is the first one from the panel and was doing the testing there. any ideas?
danbell78 is offline   Reply With Quote
Old 10-29-2012, 10:36 PM   #2
joed's Avatar
Rewards Points: 11,576
Sounds more like a ground issue than a neutral issue. If it was a neutral issue the voltage between the hot and neutral would not be equal.
Old 10-29-2012, 11:07 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,858
I think we would need more complete diagnostic testing to tell you exactly what's wrong, but it does sounds like a possible loose neutral connection. Have you tried tightening all the connections? Have you measured the neutral-to-ground voltage on other circuits, and between the busses in the panel?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-30-2012, 06:56 AM   #4
Rewards Points: 1,418
One sure sign of a neutral problem, the red/white and black/white voltages seesaw (while still adding up to about 240) when you turn on more lights or appliances on one side.
Old 10-31-2012, 12:03 AM   #5
dmxtothemax's Avatar
Rewards Points: 5,098
what are you testing the voltage with ?
Remember digital meters can give eronious readings.
Test with an anologue type meter !Name:  anologue volt meter.jpg
dmxtothemax is offline   Reply With Quote
Shared neutral on more than one circuit Richo Electrical 82 04-28-2013 08:23 AM
Open neutral, hot & grd reveresed? th3chainrule Electrical 7 01-24-2011 02:42 PM
Induction Cooktop, no neutral (?!) andersol Electrical 7 09-28-2010 04:47 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
