Shared Neutral On More Than One Circuit - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 05:36 PM   #46
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by jproffer View Post
He made it sound like a personal choice.
If it's against code, then so-be-it...if it's spec'ed out as EMT, then ok. Just thought maybe he had reasons other than "forced" reasons.
Oh, i have no idea, sounds like he's just a commercial guru, they get tunnel vision on other wiring methods outside of the commercial atmosphere...
Old 04-20-2013, 05:36 PM   #47
custom user
Rewards Points: 150
why would you not use PVC conduit?
Metal is better in case someone slops some paint on a ground screw. I guess.
JasperST is offline   Reply With Quote
Old 04-20-2013, 05:37 PM   #48
E2 Electrician
??? why would that change anything?
Old 04-20-2013, 05:37 PM   #49
jproffer's Avatar
Rewards Points: 706
And there's nothing particularly wrong with that
I was just curious.
jproffer is offline   Reply With Quote
Old 04-20-2013, 05:39 PM   #50
E2 Electrician
I was just curious.
i know, but when someone is fixated on how they do things, they bring to much opinion into what is required, sometimes it can cost someone money they didnt need to spend on doing a job.
Old 04-20-2013, 05:39 PM   #51
jproffer's Avatar
Rewards Points: 706
I don't get it. I'm not trying to be smart, I just don't know what you're getting at.
Old 04-20-2013, 05:41 PM   #52
jproffer's Avatar
Rewards Points: 706
Very true. I haven't compared prices on conduit in a long time, but if you're working for someone else, insisting on conduit that costs (let's say...throwing out a number) twice as much could cost you the job. (Not talking as an employee...but as a contractor working for a customer)
Old 04-20-2013, 05:43 PM   #53
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
If you were bidding a 2000amp feeder, I highly doubt you would pay for EGC within the metal raceway with your own money.
I was strictly talking about the normal 15, 20 or 25 amp lighting and outlet type circuits which use standard 10, 12 or 14 ga wire, not industrial applications!
Sorry if I wasn't clear on that but the thread was about the OP's normal non industrial wiring and that was what I had in mind.
RWolff is offline   Reply With Quote
Old 04-20-2013, 05:45 PM   #54
E2 Electrician
Just so you understand my point, i'm not against you in favor of pulling in an EGC, but if someone asks if it is required, you have to just say "no" and let the installer make the decision... saying its better to pull a EGC is just a false statement. Hope thats respectful enough.
Old 04-20-2013, 05:47 PM   #55
RWolff's Avatar
Rewards Points: 502
Ok, this is 2 years old, but at least I'm not the first to comment since then
so I'll bite.....
The better question is, why would you put matches next to a gasoline can?
Plastic burns, it also gets brittle over time, it has no grounding ability either.
I don't trust plastic.
Old 04-20-2013, 05:52 PM   #56
custom user
Rewards Points: 150
I was being sarcastic, based on "With the separate green grounding wire, the metal conduit still acts in the capacity of a redundent ground were something to go wrong, or some fool forgets to connect the breaker box end of that wire and it's just left danging in the box."
For the record, we used metal conduit in the military (never for a ground/backup though) for protection and explosion prevention.
Old 04-20-2013, 05:52 PM   #57
RWolff's Avatar
Rewards Points: 502
Yeah, that's clear, and fair enough, for myself, my own opinion and circumstances, I prefer the added ground wire. I just prefer to do a little higher caliber of workmanship than the minimum required, or what just gets by, I always overbuild and overspec.
That is why for example, if a 2x4 stud is the minimum required size, I use 2x6 or even 2x8 if I feel it's right for the project.
Old 04-20-2013, 05:56 PM   #58
RWolff's Avatar
Rewards Points: 502
Ok I see
Old 04-20-2013, 05:59 PM   #59
RWolff's Avatar
Rewards Points: 502
Heh, ok.
Yeah, the metal conduit in that application in the military would be for mechanical protection of the wires, same reason it's required in exposed areas like a basement, laundry room etc where romex if used could be damaged.
Old 04-20-2013, 09:11 PM   #60
jproffer's Avatar
Rewards Points: 706
I still don't see the point.
Matches next to a gasoline can is a silly comparison, so I won't even comment on that one.
Plastic burns...so what?...you're whole house will burn if it's lit up.
And as far as "no grounding ability", you pull a seperate ground anyway right ...so what's the difference.
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 02:36 PM
Poor neutral connection in outlets Albondigas Electrical 5 10-04-2009 12:32 AM
Help if it's not too late!! Cyndi Electrical 255 10-10-2008 10:18 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
