I'm in the process of swapping out my old panel. I came across a 12/3 cable, where one hot feeds several receptacles and the other feeds a receptacle that was previously dedicated for an a/c window unit (house now has central a/c). Can I just pigtail the two hots together in the breaker panel and avoid a share neutral placing them all on one circuit?
Were these two hots fed from two halves of a double-pole breaker? If so, this is a Multi-Wire Branch Circuit. If done correctly, they are safe as well, but if you no longer need the a/c, probably no reason not to combine them.
If breaker space is not at a premium why bother combining them?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
