To Share A Neutral Or Not - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 02:49 PM   #1
to share a neutral or not
I am installing a ceiling fan and lite in a stairwell, lite and fan on seperate swithches using 14 gauge wire should I run 1 14/3 and share a neutral or should I run 2 14/2 wires, the light will be on a 3 way switch at top and bottom of stairs and fan will only be controlled and top of stairs, and they will get power from seperate lighting circuit with only lites on the circuit any help would be great
thanx
chip5774 is offline   Reply With Quote
Old 08-12-2009, 03:36 PM   #2
Rewards Points: 2,350
thanx
Sure, share it. This is not the same kind of neutral sharing that occurs between two different circuits, so you are fine.
Old 08-12-2009, 05:39 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
I think you need to reread the post.
He said seperate lighting circuits.
If two circuits, then you can not share the neutral!
Old 08-12-2009, 07:36 PM   #4
It is you that needs to re-read the post The OP said:
...and they will get power from seperate lighting circuit with only lites on the circuit...
To me, that says one circuit.
Old 08-13-2009, 10:40 AM   #5
jbfan's Avatar
Rewards Points: 420
Maybe the OP will return and clear things up!
Old 08-13-2009, 10:59 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I think it is clear that he is bringing power to the switch box from a single lighting circuit. His concern is the 14/3 to the fan having only one neutral for the fan and dome light. I don't think he is talking separate light not that it would make any difference. It's no problem as I see things. This is always done with a 14/3 to the ceiling fan from the switch box. I think this is reasonably close to what he is asking.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-13-2009, 11:47 AM   #7
Rewards Points: 1,500
To minimize confusion there should be just one hot feed for the fan/light unit coming to the switch box or fixture box whichever is applicable. Even though they may be on the same circuit now, two hot feeds arriving in the same outlet box should not have their neutrals tied together as some day the feeds may be moved to different circuits.
When the fan/light unit has only one neutral coming out of it, the fan and the light may never be powered by different circuits. Using the 14/3 cable down to the switch boxes and power feed, the correct connections are assured since there is just one white wire in the cable to connect the fan/light unit to.
Old 08-14-2009, 08:39 AM   #8
thanks for all the help guys, stubbies' diagram is correct it is what I was wondering about the light and fan will be on the same circuit it is a circuit designated for lights in the house sorry for any confusion
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
