Severed USB Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 03:08 PM   #16
It's a USB cable, it plugs into a USB port
Old 06-21-2009, 03:41 PM   #17
Actually he said it was an extension cable, so USB A male to A female.
jerryh3 is offline   Reply With Quote
Old 06-21-2009, 03:45 PM   #18
actually he called an "etension chord"
and unless its for one of the weird cables it should be standard
I only have one, wife uses it as most of the USB ports are on the back of the PC. And the mini tower is on the floor
I think I tried soldering a small gauge wire years ago
Didn't work out so well
Old 06-21-2009, 04:39 PM   #19
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
both ends?
Old 06-21-2009, 05:07 PM   #20
Since its a USB cable then yes
Old 06-21-2009, 08:12 PM   #21
nap
You talking to me?
nap's Avatar
then what is the question?
Now, if it had a USB connector on only one end, it would be a conversion cable (or adapter cable or whatever you like to call it) ans we are back to a different ballgame.
Hold it. This all started when you said something about special cables and proprietary designs and everything. You can't just turn around and start agreeing with me. How do you think that makes me look?
Old 06-21-2009, 08:25 PM   #22
Although nothing is a sure bet with computers there are 4 wires used red ,white green and black.sometimes two black the ground. strip the wires 3/4 inch each ,slide on shrink tubing twist or solder together matching colors use heat gun to shrink the tubing and you should be up and running. Sollution 2 contact Cables to go online www.cablestogo.com [IMG]file:///G:/Users/JOHNMC%7E1/AppData/Local/Temp/moz-screenshot.jpg[/IMG] or try http://www.zytrax.com/tech/pc/serial.html
[IMG]file:///G:/Users/JOHNMC%7E1/AppData/Local/Temp/moz-screenshot-1.jpg[/IMG][IMG]file:///G:/Users/JOHNMC%7E1/AppData/Local/Temp/moz-screenshot-2.jpg[/IMG]
reelwood is offline   Reply With Quote
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
