#1 |
Severd Wire help.
Hello, When I bought my house the service running from the house to the garage was cut. the wiring in both boxes is complete. Its just missing a 35ft section. It was cut where the cable leaves the house and where it enters the garage. I opened up the panel in the garage and there are two 6AWG and one 8AWG wires all aluminum running into the box. each 6AWG wire runs to a 100amp breaker and the 8AWG runs to what I assume is a grounding bar of some sort. What I want to know is what would be the easiest way to get [power out to my garage. I have been told run all new wire. Also that I could put a J-box where the wire enters the house and just run new wire from there to the garage. I don't really have any idea, I'm just looking for some advice.
#2 |
Severd Wire help.
I would refeed it and so you know 6awg is NOT good for a 100a
Electricity will kill you if you give it a chance |
#3 |
Severd Wire help.
Yes I know, I was told that 6AWG is only good for 50amp service. I think that is why each 6AWG wire goes to seperate breakers. Also, other than the main breakers there are only 100amps worth of breakers in the box. A 30amp 2x20amp and 2x15amp.
#4 | |
Pure Genius
Severd Wire help.Quote:
#5 |
Severd Wire help.
I will be completely honest I am not sure what you are talking about so here is a picture of the box in the garage.
#6 |
Pure Genius
Severd Wire help.
I cant see the pic
#7 |
Severd Wire help.
cant see it at all or to small to see.
#8 |
Pure Genius
Severd Wire help.
Its just a grey box in my screen can you see it?
#9 |
Severd Wire help.
Since current code requires a four wire feed you need to run a new cable or conduit from the start.
Do not PM with questions that can be asked in a forum. I will not respond. |
#10 |
Severd Wire help.
I can see the picture but it is small I will try to re post it. If i do run new wires all the way can i just hook up the new wires like the old ones are? Or do I need to do it in a specific order.
#11 |
Severd Wire help.
lets try this.
#12 |
Severd Wire help.
lets try this.
#13 |
Pure Genius
Severd Wire help.
I cant see what the breaker size is but you have a multitude of issues there. My suggestion is refeed from main panel and install new sub panel in garage
#14 |
Severd Wire help.
why would I need to install a new sub panel? I cant just run new wire and hook it up the existing panel.
#15 | |
Pure Genius
| Display Modes | |
| THWN wire; Gray pvc Conduit; and GFCI receptacles | Buzzy | Electrical | 29 | 09-26-2012 03:41 AM |
| ceiling fan | wicked97 | Electrical | 4 | 08-21-2011 09:12 AM |
| convert 3 wire range junction box to receptacle | filby | Electrical | 0 | 06-05-2011 02:33 AM |
| HALP! Master/Remote Dimmer troubles! | Confuserated | Electrical | 9 | 02-12-2010 04:30 PM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
