-   -   Severd Wire help. (http://www.diychatroom.com/f18/severd-wire-help-163347/)
ramick 11-14-2012 04:31 PM
Severd Wire help.
Hello, When I bought my house the service running from the house to the garage was cut. the wiring in both boxes is complete. Its just missing a 35ft section. It was cut where the cable leaves the house and where it enters the garage. I opened up the panel in the garage and there are two 6AWG and one 8AWG wires all aluminum running into the box. each 6AWG wire runs to a 100amp breaker and the 8AWG runs to what I assume is a grounding bar of some sort. What I want to know is what would be the easiest way to get [power out to my garage. I have been told run all new wire. Also that I could put a J-box where the wire enters the house and just run new wire from there to the garage. I don't really have any idea, I'm just looking for some advice.
Julius793 11-14-2012 04:39 PM
I would refeed it and so you know 6awg is NOT good for a 100a
ramick 11-14-2012 04:52 PM
Yes I know, I was told that 6AWG is only good for 50amp service. I think that is why each 6AWG wire goes to seperate breakers. Also, other than the main breakers there are only 100amps worth of breakers in the box. A 30amp 2x20amp and 2x15amp.
Dierte 11-14-2012 05:04 PM
Is the breaker that the wire runs to a double pole 100 or a double pole 50? I just want to make sure we are all on the same page.
ramick 11-14-2012 05:19 PM
I will be completely honest I am not sure what you are talking about so here is a picture of the box in the garage.
https://mail.google.com/mail/u/0/?ui...972534784-1&zw
Dierte 11-14-2012 05:25 PM
I cant see the pic
ramick 11-14-2012 05:37 PM
cant see it at all or to small to see.
Dierte 11-14-2012 05:40 PM
Its just a grey box in my screen can you see it?
joed 11-14-2012 05:45 PM
Since current code requires a four wire feed you need to run a new cable or conduit from the start.
ramick 11-14-2012 05:50 PM
I can see the picture but it is small I will try to re post it. If i do run new wires all the way can i just hook up the new wires like the old ones are? Or do I need to do it in a specific order.
ramick 11-14-2012 06:05 PM
1 Attachment(s)
lets try this.
ramick 11-14-2012 06:12 PM
1 Attachment(s)
lets try this.
Dierte 11-14-2012 06:25 PM
I cant see what the breaker size is but you have a multitude of issues there. My suggestion is refeed from main panel and install new sub panel in garage
ramick 11-14-2012 06:29 PM
why would I need to install a new sub panel? I cant just run new wire and hook it up the existing panel.
Dierte 11-14-2012 06:36 PM
You can leave it but just make sure all of your breakers match the manufacturer. Right now it appears that you have mixed breakers.
