Several Receptacles/Switches Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 09:34 AM   #1
Rewards Points: 774
I went to turn on my window a/c and noticed it didn't work. I also see that another outlet in the room has no power as well as our three way light switch to hallway light.....there weren't any breakers that were tripped, but I reset them anyway. I still don't have power.....any ideas?
cibula11 is offline   Reply With Quote
Old 08-08-2012, 09:35 AM   #2
Licensed electrician
Rewards Points: 1,622
The heavy load created by the window AC may have caused a connection to fail and create an open circuit. Look for a loose connection at the last working or first non-working receptacle.
Old 08-08-2012, 09:46 AM   #3
Rewards Points: 774
Would I just be tightening those connections?
Old 08-08-2012, 09:50 AM   #4
They may be in backstabbed connections. You could remove the wires from the stabs and use the screw connections.
Old 08-08-2012, 10:49 AM   #5
Rewards Points: 774
They were backstab...but there's barely any wire. I pigtailed to extend them and replaced the receptacle....but it still isn't working. The other outlet isn't working, but has power to it???? Not sure how it could have power but not work.
Old 08-08-2012, 11:51 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
That would be were the loose connection is.
It reads fine with a meter, but when you put a load on it, the connection opens up.
You need to check all the receptacles on this circuit.
Water Filled Gas Furance Not working szym0n HVAC 1 02-21-2011 04:46 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
