SEU / SER Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 08:12 PM   #1
SEU / SER cable
What is the difference between SEU cable and SER cable? Where is each type used?
Thank you,
Mike
Mike2401 is offline   Reply With Quote
Old 08-05-2010, 08:16 PM   #2
Electrician
Proby's Avatar
http://forums.mikeholt.com/showthread.php?t=86942
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
Mike2401 (08-05-2010)
Old 08-06-2010, 12:31 AM   #3
Electrical Contractor
kbsparky's Avatar
They are both "type SE" cable.
Type SE style U has a concentric grounding conductor, with individual strands wrapped around the insulated, current-carrying conductors.
Type SE style R has a regular grounding conductor usually bare and stranded.
Both styles have an outer PVC jacket on the cable assembly.
Here is a spec sheet from one manufacturer on these cable assemblies.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Mike2401 (08-06-2010)
Old 05-04-2011, 01:04 AM   #4
Rewards Points: 512
Do SE Style U and SE Style R have different applications?
For example, I have a house that I'm upgrading, as pic'd below. There's no disconnect involved outside, so the panel inside is the main panel. It is to be 200amp. My plan is to use 4/0 SEU AL from service drop to meter, and from meter to panelboard. Will this be compliant?
At this point, all power to the house is turned off, and I plan on finishing it this weekend.
Old 05-04-2011, 08:20 AM   #5
Licensed electrician
Rewards Points: 1,272
As long as it is allowed in your area, SE-U would be fine for that application.
sirsparksalot (05-04-2011)
Old 05-04-2011, 10:03 AM   #6
I ask the impossible!
Rewards Points: 640
I've been through this and other issues relating to my own project to upgrade my service, except I'm moving the service entrance so we'll have the old service in use until the POCO comes to disconnect it at the same time they connect the new.
The thread linked above is interesting but was focussed on SE-U vs. USE, although it later also included a photo of SE-R as well.
Try to find out if your POCO has information about service entrance wiring online because I've found that my POCO has info and it is possible to find other POCO online where things are done differently.
For example, DTE (still can't help thinkng of them as Detroit Edison) does not want the ground enterring the service meter socket. In my general internet searching on the topic I found a PoCo in Mississippi that does.
So for my installation, SE-U was more appropriate than SE-R. SE-U has 2 hot conductors and a third which the strands are around the 2 hot conductors. SE-R has 4 conductors. In my installation, the 4th conductor would've been unused. Since I'm using rigid metal conduit for service mast, I'd have to cut off that 4th conductor where it goes out of the weatherhead and where the cable enters the socket.
Another option might have been to go with individul conductors, but SE-U was available at Home Depot.
(I had actually been to an electical supply to get indivdual conductrs for my underground run to the garage, and was also sold SE-R for the service upgrade - but it's a major inconvenience for me to goto the electric supply because their hours are entirely hours when I'm at work.)
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-04-2011, 11:00 AM   #7
SE-R is typically run to a subpanel.
Old 05-04-2011, 02:17 PM   #8
Rewards Points: 512
So the difference, then, is that style U has two ungrounded conductors and a stranded ground (which is to be used as the neutral), while style -R has 2 ungrounded conductors, an insulated neutral and a stranded ground?
Old 05-04-2011, 03:12 PM   #9
Rewards Points: 512
bumpers
Old 05-04-2011, 03:30 PM   #10
Rewards Points: 640
Here is one company's pages on SER and SEU cable, this is the brand carried at HD and Lowes I believe at least locally:
http://cerrowire.com/default.aspx?id=37
http://cerrowire.com/default.aspx?id=31
Since we're talking about 4/0 aluminum for 200 amp service, I'll use that as an example. The SEU has 2 4/0 XHHW-2 cables with 19 strands that bundle to 4/0. The SER cable has 3 XHHW-2 conductors at 4/0 and an uninsulated conductor at 2/0.
I'm not sure what manufacturer the electric supply house I went to uses, but the SER cable I got there actually had black, red and white colored insulation on the 3 wires. I think sometimes you might get black with a red stripe, black and black with a white stripe.
The Following User Says Thank You to WillK For This Useful Post:
Old 09-10-2014, 09:05 PM   #11
Rewards Points: 512
Deleted
Installation is the Reverse of Removal.
Old 09-11-2014, 07:04 AM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's not a stranded ground, it IS the neutral conductor...
Yes, but you can also order it with 3 ungrounded conductors, 1 grounded conductor and a bare grounding conductor.....
Old 09-11-2014, 07:09 AM   #13
E2 Electrician
Thank you,
Mike
SEU - 2 insulated conductors, 1 uninsulated concentric neutral conductor
SER - 2 insulated conductors, 1 insulated neutral conductor, 1 uninsulated grounding conductor.
SEU would be used before your first disconnect where a grounding conductor is not required, once you install your service disconnect anything after that requires SER type cable.
The Following User Says Thank You to stickboy1375 For This Useful Post:
rjniles (09-11-2014)
Old 09-11-2014, 09:04 AM   #14
This thread was from over 3 years ago.
electures (09-11-2014)
Old 09-11-2014, 04:51 PM   #15
E2 Electrician
Who brings this **** back to life?
electures (09-14-2014)
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
