Is This Setup OK? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 03:16 PM   #1
Is this setup OK?
I have a four-way light switching setup in my house and I need to move one of the switches. The box the switch is in has lots of other stuff going on, but here is what interests me:
1. The power feed for the light circuit is to the 3-way switch in this box.
2. All of the common wires in the box are wire-nutted together. Nothing to the switches themselves.
3. Instead of a 3-wire traveler, it is using a 2-wire, apparently with the white taking the place of the red.
4. inside the box with the 4-way switch, the white and black are connected to the traveler contacts.
Since all I'm going to do is move this wire-for-wire to a location a foot away, I'm not concerned that it will work, But, is this a code problem? None of the grounds are connected to the switches either, just nutted together. The house was built in 1978.
Thanks,
feeno
feeno is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
old furnace with bizarre filter setup utek HVAC 2 10-14-2013 09:49 PM
pump setup for areator and sprinklers nanakr Landscaping & Lawn Care 0 05-26-2011 06:55 PM
New House Structured Wiring Setup for CATV gregsenne Electrical 13 02-19-2009 09:00 PM
home theater setup cannouu Electrical 5 04-09-2008 07:01 AM
