Set Screw Connector For EMT Conduits Not Bottoming - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 05:25 PM   #1
Rewards Points: 1,646
Set screw connector for EMT conduits not bottoming
Well, I got a 1/2" set screw connector along a run of EMT conduit in the attic that came loose.
May be from someone stepping on it, or may be whoever ran it pulled on it too hard on the other end.
Anyways it came apart.
I loosened up the connector and used all my JEDI FORCE to pull the pipes back together as much as I could and with a helper was able to get the pipes back into the connector and tightened the set screws.
HOWEVER, I know the pipes didn't bottom to the full depth inside the connector, they went in deep enough for the screws to catch, and that is after I went downstream to the next connector and loosened that one and steal about 1/4" from there.
So now I have TWO EMT connectors that are not bottomed. I used electrical tape over the joints to give it extra reinforcement. I thought about using epoxy glue to glue it to ensure no chance of it coming apart.
Is that OK? Or not?
It would be a real pain to run new conductors as I have 4 #12 in there over 75', and adding a box in the attic is trading one problem for another IMHO.
miamicuse is offline   Reply With Quote
Old 07-20-2014, 05:48 PM   #2
Rewards Points: 1,192
If it has a ground wire I wouldn't worry.
bobelectric is offline   Reply With Quote
Old 07-20-2014, 06:22 PM   #3
Rewards Points: 3,396
I would worry if you crimped into the edge of the conduit as it may nick into conductor.
As stated (and the conduit isn't crimped), if there's a ground don't worry much.
You done good stealing from the other side to make up the gap. You could also take some up from the couplings if you wanted.
Also, if your concerned about ground if there is non you could put an external bonding jumper.
epoxy? not sure about that.
1- ground
2- protection
ritelec is offline   Reply With Quote
Old 07-20-2014, 07:14 PM   #4
There is no ground conductor the conduit acts as ground. The conductors are fine not crimped or nicked.
The thinking behind the epoxy is to stop it from pulling apart again. I don't think it will just pull apart - I tried - but if someone stands on the joint and bounce up and down it probably will come apart.
Old 07-20-2014, 07:28 PM   #5
why would someone maliciously bounce on the fitting.
if your concerned put (nail) something like a piece of wood by it so they kick it or step on it instead.
The Following User Says Thank You to ritelec For This Useful Post:
petey_c (07-20-2014)
How to screw in a gutter mj12 Roofing/Siding 2 06-28-2013 09:16 PM
is ground screw on light switch necessary SS396 Electrical 17 01-12-2013 03:48 PM
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 08:30 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
