Service Upgrade Options - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 05:20 AM   #1
Weekend Warrior
My 200A service is pretty well maxed out, according to my load calculations. All appliances are electric in my 3300 SF house. I am adding a 100A subpanel in my garage and would like to avoid main breaker trips when working in the garage so I am considering a service upgrade. My POCO will provide a 400A meter base that I would need to install and have inspected before they will energize it.
Could I install a second 200A main distribution panel right next to the existing one and have both panels connected to the 400A meter base? This would mean having two separate service entrances for the house, both connected to the meter base. The idea is to avoid having to rewire the existing 40+ circuits into a new 400A main panel and instead just add a 200A main panel where I could connect the subpanel feeder.
Or does anyone have another idea altogether?
H2O Engr is offline   Reply With Quote
Old 02-12-2010, 06:20 AM   #2
400A panels are available, but only allow 42 ckts. Adding a second 200A panel adds ckts capacity. But check local code.
Old 02-12-2010, 07:37 AM   #3
Weekend Warrior
Does a 400A meter base have provisions for connecting two 200A SE cables? Does having two adjacent 200A main distribution panels in my house meet current NEC code?
Old 02-12-2010, 08:08 AM   #4
Licensed Pro
All the 320/400A meter bases I have seen have double lugs on the load side so you can feed two 200A or one 200A and one 100A panel. If you opt for a 400A panel, be ready to open the wallet very wide.
Old 02-12-2010, 08:26 AM   #5
Weekend Warrior
No 400A panel in my future. The garage wiring project has already flattened my wallet.
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
150amp to 200amp service upgrade... theatretch85 Electrical 30 07-06-2009 05:02 PM
service upgrade work4six-s Electrical 3 07-06-2009 11:07 AM
DIY 200A main service upgrade? Philip_Soldat Electrical 54 09-07-2008 11:02 AM
Service upgrade rondo Electrical 1 05-21-2007 06:19 PM
